Question about U-Line 15R Compact Refrigerator
Mini fridge thermostat repair - U-Line 15R Compact Refrigerator
No cooling on a Mini Fridge
Does the compressor start up? It has a thermal cut off and a current stareter relay that tend to go out causing the compressor to do nothing without power in it.
May 15, 2018 | Refrigerators
My brand new Emerson 286 mini fridge just stopped working after almost 2 months.
Sounds like there is some warranty left on this unit.
Try unplugging it for some time; return power to it and see what happeng.
Another teat: Join the two wires at the thermostat t see if the fridge starts. If it starts, then the thermostat is bad.
Oct 24, 2013 | Emerson Refrigerators
Mini Fridge freezing everything
Yes, thermostat and when they go bad they eiter sop , keepgetting colder or out of calibration, I will see if I can find one, Really any small two wired refrigerator thermostat wil be fine, Sea Breeze
Mar 18, 2010 | GE SMR03BASWW Compact Refrigerator With...
Mini fridge not cooling
Feel the compressor top is it running? no? If no unplug and jump the two thermostat wires and if runs replace thermostat. If compressor is running and not cooling there may be a freon leak inside the walls of fridge or inside the evaporator. Sea Breeze
Feb 07, 2010 | Refrigerators
Which wires go wear when installing a new thermostat in my mini fridge?
In a mini fridge there are only two wires to the thermostat. I really does not matter which wire goes were because all it does is turn it off and on. Sea Breeze
Aug 26, 2009 | Haier HSA04WNC Compact Refrigerator
Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Apr 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
U-Line 15R Compact Refrigerator Logo
Top U-Line Refrigerators Experts
Elie Balas
Marvin
Marvin
brokenrubber
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
