Television is from 2003 but has worked excellent for years. Today it has been shutting itself off..problem does not seem to be electrical as far as outlets in my residence. Thanks.
SOURCE: RCA hd56w66 56in. hdtv
I JUST LOOKED UNDER RCA.COM AND FOUND THIS .. IM TO AM HAVING THIS PROBLEM.. ITS THE LAMP. IT SAYS IT ONLY NEEDS A FLAH HEAD SCREW DRIVER TO GET TO IT BUT YOU NEED THE HEX WRENCHES TO OPEN THE BACK UP.. THE LAMPS ARE RATHER EXPENSIVE. BUT I WILL TRY THIS BEFORE I PAY 216.00 FOR A SERVICE CALL THAT DOES NOT APPLY TO THE WORK DID ON THE TELEVISION..SO I NEED TO ORDER THIS LAMP...HOW BOUT YOU..
SOURCE: Our 61
THAT SOUND LIKE A SAFETY SWITCH TO KEEP FROM DAMAGEING YOUR SYSTEM. TAKE IT TO A REPAIR SPECIALIST.
My friend had the same problem. There is some display bulb that is on its way out. They aren't cheap. Find a 2nd hand TV parts/repair shop, They usually have cheap used ones from discarded units, and will know what you need!
