This means that there is a sensor in the unit that cannot detect the Y axis stepping motor location at startup. This unit is very delicate and needs to be serviced and recalibrated. It wont be cheap to have done.
If you are no good at chasing wires and signals or deciphering trouble codes, call your favorite local appliance repairman. Otherwise, google searching your model number along with another keyword such as:
failure
code
error
manual
you will find solutions
Sounds like it is trying to boot from the disk? If you have a floppy disk in the drive take it out and restart If still not wiorking it probably needs a new floppy drive.
Is because is similar to old tv's. You have to take it out the screw exavtly below the monitor, there is a hole you should introduce a allen key 3 mm .after you take it out the screw uou are able to take the monitor out and move the tv controls on the board, brightness and contrast until you have better image.
