SOURCE: change language in asus pc eee
Do you mean you want to change the language for windows? or what are you talking about?
SOURCE: How to reformat ASUS Eee PC 900 notebook?
I have the linux version, not sure if you have the windows version or if it really matters. If you are looking to "reformat", you can go with the other suggestions with the USB stick. However, if you are reformatting to get back to the default settings, power on the computer and immediately hold F9. This will bring you to a screen that gives you the option to "restore factory defaults". You will lose all your previous settings, but if you were reformatting anyway, that's probably not a big concern.
SOURCE: Asus Eee pc 900 can't boot (blank screen)
Just had the same thing happen, and I thought it was the motherboard. Then a tech friend removed the battery and held the power button down. Then he replaced the battery, and it booted up fine! Good luck...
SOURCE: AC Power supply overheating for ASUS eee PC
If the pc is fully charged, dont leave it plugged in. Mine gets hot but I've experienced ones that were hot to-the-touch...I'd say be careful leaving it on charge when you are not at home.
Asus Eee PCs run on the Windows XP SP2 operating system. Accounts in Windows XP SP2 can easily be password-protected, but the same password can just as easily be forgotten.
At moments like this, you'll wish you had chosen a password that is both secure and easy to remember, or kept a record of it in a private place.
The quickest way to get back on the computer is to seek out someone with an administrator account on the computer.
Press "Control" + "Alt" + "Delete" at the same time on the locked screen.
Select "Switch User."
Remember, only an administrator account registered on this computer can unlock the computer.
Type in "administrator" in the user name box.
Type the password that corresponds to the administrator user name in the password box .
Click "OK." The Asus Eee PC is unlocked.
Hope this helps
