What is error code 20?
SOURCE: crosley front load washer one year old. doored
your drain pump or hoses are blocked with foreign material,either coins,hairpins,detergent residue from earlier washings,remove the front lower access panel if provided to access the drain hoses and pump and also check the drain itself,some washers have the access door in the back side of the machine,if the stand pipe in the house is slow to drain it can back up and cause back pressure and the machine will sense this and stop also
SOURCE: front load crosley washer-door is
Use a wet dry shop vac and attach it to the end of the drain hose and remove all the water this will unlock the door.then you need to look at the drain pump and look for any obstructions that may be blocking the flow of water or stopping the impellar wheel.
Hello protocolu898 - Do you want to know how to display an error code on the washer? Or do you have an error code do you need assistance with?
Hi - Are you certain the error code is L7? This manufacturer does not have any L7 error codes for any washer or other units. I understand that it will not spin either; does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly.
