Question about KitchenAid K45SS Classic Stand Mixer
My preeti mixer grinder 550 watt circuit breaker gone is it available in Cleveland U.S.A
2 Suggested Answers
6ya staff
SOURCE:
Bob Hewitt
  • 130 Answers
SOURCE: My Preeti Mixer grinder stopped working 750 watt,
Your circuit breaker (load protection button) was popping for a reason and that reason has evidently gotten much worse. Possible causes are a short circuit in the wiring of the motor or a heavy mechanical load on the motor such as a bad bearing. Here is the service manual for your mixer. It contains all the information you need to fix your problem.
http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Once you have isolated the problem here is the parts list so that you can search the internet by part number for the replacement part.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Bob
Posted on Apr 19, 2010
Wear to find a spare khife for an MaxiMatic HA-3433A Elite Platinum 550-Watt Stainless Finish Meat Grinder
contact the manufacturer through their website support they probably have them available to purchase
Apr 05, 2015 | Food Mixers
KitchenAid mixer,model # KG25H0XMC5 will not turn on.
Check different outlet. Make sure the outlet isn't at fault.
Aug 01, 2014 | KitchenAid New Professional 5.5 QT...
My preeti lavender stopped workng suddenly
If its new, I would return it for warranty.
Dec 31, 2012 | KitchenAid ProLine 600 Stand Mixer
Where can I get like the fruit & veggie strainer/grinder an other accessories for the 700 watt wolfgang puck stand mixer? Since it's different from the kitchenaid models. Thank You! ken
Replacement parts for Wolfgang Puck Stand Mixers are available here:
http://www.wpcookware.com/categories.asp?cat=32
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Dec 12, 2010 | Wolfgang Puck Stand Mixer
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
My daughter's Kitchenaid Artisan 325 watt mixer had a malfunction last night. The unit itself is less than 3 years old. It had been running on high for approximately 5 minutes when sparks began to fly...
Sorry cant solve this but mine did the same. Mine is almost 4 years old now. Have you found out what the problem was with yours? Have you sent it back? Nicky.
Aug 02, 2010 | KitchenAid KSM150PS Artisan Series Stand...
My Preeti Mixer grinder stopped working 750 watt, what could be the solution? It worked for two months after repeatedly pressing load protection button but now completly stopped responding. Can I bypass...
Bob
Apr 10, 2010 | KitchenAid K45SS Classic Stand Mixer
The pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
MX-AC300 Mixer Grinder Got from India 2 months back Not working.Tried Reset Button too.
There is a great guy on Gerrard street in Toronto, who can fix mixer grinders and has parts also like breaker/reset switch etc.
The store is called Appliances 220, Ph # 416-778-9908.
Hope this helps.
Sep 24, 2008 | Food Mixers
KitchenAid K45SS Classic Stand Mixer Logo
67 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
