Ryobi 18-inch Electric Chainsaw Chain Saws Logo
A
Anonymous Posted on May 07, 2014
Chain came off and brake won't reset - Ryobi 18-inch Electric Chainsaw Chain Saws
Chainsaw chain sprocket won,t turn
this seems to be a chain brake that's applied , try turning off chain brake by pulling back on hand guard till a click is felt
some folks moving up from an older saw to a more modern saw are not so familiar with chain brakes and don't understand them and how they work
1helpful
I have a Husqvara 550 chainsaw. After chain popped and I put it back on, the chain won't move. It's on the gear and everything. Is there a brake or something preventing the chain from mov
There will be a chain brake, grab the brake handle and pull it firmly back to the top handle, this should didd engage the brake, if the chain has de railed the drive lonks will have burs on them which will make it tight in the bar, you need to file all these burs off.
Cover won't go on.round metal strip won't fit on round spindle that turns chain.E-235.Do I need the break bar?It doesn't line up either. DB
Sounds like the chain brake was set when you took the cover off. You need to disengage the chain brake (release it) so the round spindle will fit inside. Look for the two parts (one on cover, one on saw) that match up at the base of the chain brake. You won't be able to fit the whole cover on, but if you can line up where the metal triangular gear engages the chain brake, you can give it a snap to disengage it. What I have done in the past is to line up the two parts and push down on the top of the cover where they meet so as much of the gear is in the chain brake release as possible ( I put a knee on it ) and then give a snap to release it. Be careful though, because the cover part is plastic and you don't want to strip that part of the chain brake assembly. Good luck.
Runs but the chain won't move? Poulan
This sounds loke the chainbrake has activated, grab the hand guard and pull it fimly fully back to the top handle until it clicks and the brake is of, now try again.
I can't unlock the blade.
Do you mean the chain won't move, or you can't get the blade off? The chain brake must be off to allow the chain to move. The chain brake handle has a housing that engages a gear attached to the chain brake inside the cover where the blade is attached. The brake must be off to remove the cover (usually held on by two nuts). The blade tension screw should be loosened to allow the blade to be removed, then retightened when replacing the blade. Tightening it pushes the blade out from the saw, so if it is tight, you won't be able to remove the blade. Hope this helps.
Aug 27, 2011 • Garden
Chain won't move when motor running
Sounds like the chain brake is on, grab the hand guard and pull it firmly back to the top handle to release the brake.
Chain won't move but when i take chain off yhe clutch will
The chain brake is activated, pull the hand guard fully back to the top handle until you hear the click of the brake loading
4helpful
2answers
Cannot get the chain cover on the Farm Tough the brake will not seat right on the chain drive
The chain brake is tripped. try this:
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you don’t have a vise a large C clamp to a work surface might work, you may still need a block or two of wood. HTH
Lou
It takes considerable force to reset the brake. I should click when it nests in the detent. If you are unable to reset it try your local chainsaw seller/mechanic, probably free. A spare chain purchase would be a nice "Thank You" HTH
Lou
1helpful
It starts but chain not moving oil leaking past chain
Either the chain brake is on or the chain is too tight To reset chain brake pull the guard hard back toward the handle and I mean hard! They have a really strong spring and you should hear a "clack" when it resets Hope this helps
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
