What do you plan on doing with your old wireless router? You have a new one, are you trying to use the wireless part or the router part of the old one?What do you plan on doing with your old wireless router? You have a new one, are you trying to use the wireless part or the router part of the old one?
You can't post conmments that contain an email address.
Have you checked that the signal on your new cable modem/router is strong enough to reach your wireless devices? You may need to re-site the cable modem to get better coverage in your home. Your old one probably worked fine in the same position but that doesn't mean a new one will. There are a few things you can try to get the best of the range it has. Internal walls and furnishings all play a part in reducing the effective range of the router. Most routers will give you at least 50 metres indoors. Keep the router as high and as far away from walls as you can, this will greatly improve the range. Try to ensure the router is not screened by large near by metal objects such as steel PC cases, these will absorb wireless signals and reduce the range.
You must hook these particular items up in a specific sequence. First power down both the modem and the router, only connect the modem to the isp until all appropriate lights on on. Next plug cat 5 to router where it is labeled internet or wan if neither label then to #1. until alights come up on router. Hope this helps.
it may be the problem of the version control.you sure you have downloaded.the correct version.
else check the back of the router the model and the version.
and also uninstall the old driver properly and reinstall.
because when your old and new version is in conflict.it doesnt work.
This is a sign of an old router/modem. Also, try unplugging all of plugs that connect to the router/modem. Also, is this affecting you in connecting to the internet? if so, I recommend purchasing a new router/modem. They are very cheap now-a-days. :)
Hi, You can not use a router to connect a computer to another wireless router. You need to purchase a wireless adapter if you want to connect a computer wirelessly to the network. There seems no other way of doing this.
Let me know if you need any further help regarding this.
1. Power OFF the router then modem
2. Wait for 5 minutes
3. Power ON the modem first and wait for the light to be steady.
4. When the lights are steady on the modem, turn on the router.
