Question about Frigidaire ATF6000ES Front Load Washer
How much is a control panel for the affinity atf600fs1
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: drum wont drain
We had the same problem and the repairman found a Color Catcher sheet clogging the outlet drain inside the machine. Not covered in the warranty but after he removed it, runs like a charm. And cost us $114.00. We called the color catcher hotline and they sent us $50.00 for our problem.
Posted on Mar 20, 2009
How do I reconnect the control panel wiring harness in a Frigidaire affinity dryer
Good Morning Friend,
I understand you want to know how to reconnect the control panel wiring harness on your Frigidaire Affinity dryer. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to reconnect the control panel wiring harness with ease. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire 134436600 Wiring Harness
Frigidaire affinity dryer loc
LOC is a generic lock code meaning the door was either locked manually or accidentally. Also LOC will lock the control panel and can be manually locked as well. Try to reset the unit for about 10-15 minutes and retry.
Aug 31, 2012 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire Affinity dryer has and error message of E68 I have tried to reset and so far this hs helped what makes this happen and how do I stop it in the future? Thank you Sue Andrews
This is a fault code for a stuck key on the board. You may have to remove the control panel and check the keys. If this does not work you may have to replace the panel or control board.
Aug 01, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
How do you remove display panel from frigidaire affinity washer
Pull out the detergent drawer, pressing the catch button in the rear of the drawer. There are a couple phillips screws through the panel around the drawer. Take those out. The display panel (including the entire plastic piece) is attached by plastic clips. Unsnap them by applying firm, controlled pressure along the top and sides of the plastic panel. Should come right out for you.
Feb 20, 2011 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity Electric dryer E68 error. dries clothes fine, then error light comes on later- after dryer has been off. Will not start unless unplugged for period of time.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Sep 15, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Fridgidaire Affinity ATF6000ES1 washing machine
Checked the internet for manuals and found one that had a blowup of the parts sequence. Also found instructions at the manufacturers site for trouble shooting and repair.
Jun 13, 2009 | Frigidaire Affinity ATF7000E Front Load...
Drum wont drain
Mar 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
48 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Marvin
Marvin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
