SOURCE: Roper Washing Machine Repair
I believe Roper washers are manufactured by Whirlpool. The following link should provide you with the necessary steps in removing the washer casing, so you can access the pump:
http://www.fixya.com/support/r397092-replacing_water_pump
If this information is not correct, or if you require additional assistance, please let me know. I hope this helps you.
SOURCE: Roper washing machine not going through rinse cycle.
Good Morning,
Sounds like your cold water valve is not opening. If you are handy with a Multimeter check the selector switch that you use to set your cold water for good continuity when you activate it. You should have a good steady reading on the meter. If the meter is fluctuating or has no reading at all the switch is bad. If the switch checks out good, check to see if there is voltage to the cold water valve terminals when the machine is calling for cold water. If there is no voltage, you will have to locate the relay or source that supplies this voltage and replace it. If there is voltage the valve is faulty and needs to be replaced.
I hope I helped you today.
SOURCE: roper washer fills and washes then will not fill on rinse cycle but goes into washing dry
Run the machine with hot only, and then cold only. Post back your results.
