I accidently bumped a button and I don't know which one now.
SOURCE: cooling light
The cooling light should be blinking. Mine did the same thing. It ended up being the fuse that was going to the dryer from the circuit breaker itself. I ended up replacing the whole heating element thinking that was the problem. Turned out to be a $17 fuse and problem solved. Hope this helps.
SOURCE: lg tromm dryer electric cooling light staying on
I called LG after seeing this light as well and they say it's supposed to stay on and should "blink" at the end of the cycle. I've never remembered this light staying on in all the years of owning this machine but she (LG rep) said it was normal. Otherwise, if you've checked everything and it's not drying clothes, you may need to have your dryer serviced. :(
SOURCE: lg dle7177 electric dryer
The cool light on the lg is on all the time. It is only actually cooling when it is flashing. You might have a blown thermostat. Call a tech and have him/her check it out.
Sgt48
