SOURCE: Deck belt
go to partstree.com click mtd,then put in your model#;then click deck assembly. it will show you your belt routing;then scroll or click the item #.it should tell you the lenth of your belt.hope this helps.please rate this;thank;s
SOURCE: drive train belt replacement. huskee, mtd.
there should be a diagram on the new belts package showing how it goes
SOURCE: I need a diagram for a 38
just make sure the direction of the belt goes clockwise (most tensioners push from the outside to the inside.if you could get the model number that would help...good luck
SOURCE: Need a deck belt diagram
I also need a deck belt diagram because a manual didn't come with my 746 SRL yard machine
