As soon as my head spun freely I knew that my shaft had broken. My upper shaft had broken right at the quick release. unfortunately, or maybe not, the upper section is sold as a unit. outdoordistributors.com has one for $26.55 part no. 180339.
Having a broken axle shaft will let the diff spin freely, allowing the transmission to spin with no resistance. Resistance/pressure is what causes your transmission to shift. No resistance/pressure means no shifting.
When you remove the recoil shroud ( housing ), the square shaft sticking out should move freely in a counter-clockwise direction and you should hear clicks when you twist. If you don't hear the little balls clicking or the square shaft doesn't move freely counterclockwise, then that square shaft is rusted onto the end of the crankshaft and must be freed before it can be removed. This is a common problem for mowers left out in the elements. Sounds like the shaft is frozen onto the crankshaft end. Procedure: First, disconnect the spark plug. Get a magnet ready because 5 little balls are gonna come rolling out on this upcoming move. Take a 1/4
Hi Kevin, Alec from VacuumSpot here. Unfortunately Dyson don't actually sell individual mechanical components to their turbine heads, so even though it is probably a pretty easy repair you can't get the parts. In this case you will have to buy a complete new head.
Unfortunately, Vanguard does not sell replacement pieces, you may have to ship it off to them in order to get it fixed. It's either that or you can buy a new pan head or quick release adapter. You can find those at www.tripodquickrelease.com, sometimes though pan heads don't come off of a tripod.
It appears that the gear case on your model is not capable of being serviced. The cost is over 300 dollars. There is a shear pin or similar connection in the case where the shaft connects to the pulleys. It has broken off and the shaft has no torque now.
The upper shaft 'T' head has a broken pin in it (the part that holds the blades. You can flip the heli upside down and slightly rotate the blade housing back and forth and IT SHOULDN'T do that. Another way to instantly identify it is dislocate the rotor head links and the upper blade housing should instantly separate) It's made of plastic.
Anyway, It's also called the "T.B.E." Toilet Bowl Effect. It's not 'really' what's taking place, it's move of a cyclic issue but the effect looks like it's swirling in a toilet bowl... You need to replace the inner shaft basically on the upper rotor. They cost anywhere from $4-7.00 bucks. It took me about 2 days of researching and purchasing another one to finally figure it out. There was another website that says the balance bar is it or the gyro has gone bad; this simply isn't true.
SOUNDS LIKE A BAD HUB TRY THIS TO DIAGNOSE THE PROBLEM
Put the transmission in park, set the parking brake and raise the chassis so one of the front wheels is off the ground while the other is still on the ground. When the transfer case is in two-wheel drive, the hubs should be released allowing the wheels to turn freely when spun by hand. If the axle shaft turns when you spin the wheel, it means the hub has not disengaged.
To check engagement, rotate the axle shaft backwards. This should lock the hub. Try turning the wheel by hand again. The axle shaft should now turn with the wheel if the hub is locked. If the hub fails to lock, the hub will have to be disassembled and inspected or replaced.
To check release, hold the axle shaft steady and rotate the wheel backwards. You should hear a click as the locking mechanism slides back out and disengages the hub. Rotate the wheel forward again and it should turn freely.
Another way to check the hubs is to raise the vehicle on a frame contact lift so all four wheels are off the ground. Then start the engine and place the transfer case in four-wheel drive and the transmission in drive. If the front wheels don't turn, look at the front axle shafts. If both shafts are turning, but one wheel is not, the problem is a bad hub on the wheel that isn't turning. If the front driveshafts are not turning when the transfer case is in four-wheel drive, the problem is inside the differential (broken side gears) or the transfer case (broken chain, shift linkage, etc.). If the driveshaft between the transfer case and differential is turning, the problem is in the differential. If the driveshaft is not turning, the vehicle is going to need repairs to the transfer case.
Hope this helps.
The little brass arm is supposed to be a safety switch. In one position the release lever bumps into the brass are and will not turn so the quick release willnot come off. In the other position the brass arm is away from the lever so it swings freely and the quick release plate will come off. With the brass arm open the quick release lever shoulde lock open until you push the quick releae in place. If none of this seem to work on your head, you may be missing parts. Try www.bogentripodparts.com
