All front loading washers will fill and drain multiple times before it finishes. Unlike a top loader, a front loading washer will take longer to run because there is no agitator and will fill with water and drain multiple times. A front loader is more energy efficient than a Traditional top loading washing machine. A washer dryer combo will take hours to complete a cycle.
After removing the three screws which pass through the L bracket into the back of the dryer:
Stand in front of the dryer and (using the palms of your hands) give the top a sharp push back on the dryer top at the left and right side of the top. The top should slide back 1 to 2 inches. Now lift the top off.
If you post again with further questions, make sure to post under the model number you have. (you posted using a combo washer / dryer, and stated you are converting to LP, which combo units are not gas.)
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
