the main drama i have with these lg washer/dryers is the drying vent blocks up with lint which causes excess heat build up around the heater and it often results in a small hole melting through the front tub under the heater vent where it joins to the plastic tub, it also results in water leaking out the melted hole when it dries but not during the wash as the hole is at the top of the tub, parts are relatively cheap for what they are but its a massive job to replace the front tub.
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
I found your answer to another person's problem with the LG washer/dryer not turning on. We have the same problem. My husband found a piece of plastic near one set of the fuses that looks warped - like it got too hot. Is there any advice you can give? It's a piece next to the box by the main power cord with a metal coil.
What little information you gave I would assume this is a top load machine, but either way you may have a bearing problem. This will take money and time to correct, to assist you further I would need a model number.
The squeaking is often the guide rollers for the tub. The bearings get dry and squeak as they turn... a bit of oil my fix the problem till you can get new rollers. The other cause could be the belt tensioner pulley...that too can be fix temporarily by oil til a replacement can be found...
before calling any repair man,
take a flashlight and carefully inspect tthe inner tub
on a few service calls with this particular complaint
ive found small nails, taks, penny nails, screws, what have you that fell into one of the holes and got stuck
barring that , i would get your bearrings checked yes
at four years you should still be inside your part warrenty if it needs to be replaced
