Razor 300001-SL Ground Force Go Kart Logo
A
Anonymous Posted on May 03, 2014
Razor go cart just clicks wont run - Razor 300001-SL Ground Force Go Kart
Why doesn't it run?
Try battery first check with digi. volt ohm meter, but yes it could be module.
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
Razor ground force go cart
I don't think this would be a problem, as long as the wheels fit the axle properly, both in diameter, and length of shaft.
3helpful
Dull razor blades after moisturizing stripe wears off
Expensive replaceable cartridges are only made to offer 4-6 "good" shaves for most people. Sorry - that's the deal. You can strop cartridges (in on direction only) on denim and pick up maybe a dozen more - search youtube for examples. I finally gave up on carts and moved to a straight razor; a razor or two will last for a lifetime with good care. There IS a learning curve for safe use and maintenance procedures. Find a straight razor forum if you want great shaves and good advice on what to buy, what not to buy and how to be safe.
Double edged safety razors are also a very good alternative for better, smoother shaves and WAY less expensive blades. Same advice - find a razor forum to save money, buy right and avoid nicks.
Replaced transformer
This go cart does not have reverse, so positive & negative wires must be switched.
Keeps clicking but wont run
i have a razor 175 but it doesent work.i just got it yesterday and charged it the whole night.it turns on fine but all it does is it just click but doesnt run.can somebody help me?
LOST DIRECTIIONS FOR RECHARGING PANASONIC WET/DRY WOMEN'S ELECTRIC RAZOR ES2207. Thanks!
You will find the instruction manual at shaveroutlet.com. See link below. When page opens, click the 'user manual' link near the 'add to cart' button
http://shaveroutlet.com/women-s/panasonic-es2207-close-curves-rechargeable-wet-and-dry-ladies-shaver.html
Printer cartridge missing
Make sure ur using the correct cartridge.....
for X2580 the cart number is 2 and 3
1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts
Clean the ink nozzel using a wet paper towel.....do not whip it ..just press and hold the nozzel....do this 3 or 4 times....
then
Install the carts...
open solution center.....click maintence tab...click on "clean to fix horizontal streaks"...
-----XXXX----
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
