-You mean it's loose and wobble...?
If so re tight its lock nut from under neat.
Good luck
Mai
This should be fixed by now but the easy fix is there is a weight under the sink to pull the hose back inside, simply put, it is either missing or it loosened and slid down. That will fix the loose hose inside the housing but you get to it under the sink... 5 min fix with a phillips head or whatever they use to tighten the clamp around the weight.
Ours may be similar. Ours requires an extra twist of the head to the right (or counter-clock-wise) when you guide it all the way back to its original placement to seat it properly in it's holder. Hope this helps.
