I I'm assuming you are taking about the body of the washer when you say casting? First Remove The Two end clips by Either Pulling on the Back Of The Clips. Now you should see two screws, remove them, pull console slightly towards you then flip it back. You will see two clips going into two slots, use a flat tip screwdriver. Insert it in the first section and push back towards the rear .pay attention to the removal as how to re installation. Also removed lid switch plus. .now open the lid lifting slightly at the back at the same time pulling the body off . Hope that helps.
