ASUS Eee PC 900 Notebook Logo
A
Anonymous Posted on May 02, 2014
Caps lock only displayed when logging on and no other times after that. Can you tell me how to activate caps lock indicator.
Turn off caps lock
Great little utility. I think it's free. Will show in your taskbar.
Here is the link.
https://www.traystatus.com/
Hell! I bought Hp probooks 4520 recently in early week it was runnig good but after a week its numpad is not working I don't know what happened to it. I tried so many thing but still not working anyone...
Hi
There is a key - Like Caps Lock - that activates the numpad, called Num Lock, and indicates that activation with light.
If not activated, the numpad will act as arrow keys.
Please, Tell us your results.
Good Luck
What is the symbol lock with an A inside lock stand. That's what lights up when I turn it on and then shut off Thank You Al
I believe the Light with the "A" above it is the caps lock indicator. This tells you if caps lock is activated or not. When it lights up as you turn it off or on, it is just booting.
Good Luck,
Rodrick
Is there a light that should come on when I press the num lock button? I can't tell if the number lock is on???
It depends on the keyboard model. Some have a number lock indicator light. There is no standard for location, either. The most common place for Caps lock, number lock, etc. on a desktop keyboard is behind the number key pad. However, some keyboards put the caps lock indicator right in the Caps lock key. There's probably at least one model that does the same for number lock. Many laptop models have no indicator, or a tiny one set somewhere in back bezel.
Some operating systems and applications have an option for displaying the status in the menu bar. If you can't find the number lock status indicator, you may have to resort to observing the behavior of the system when you hit a key on the number pad. If number lock is off, the even numbers (not including 0) will be arrow keys and the odd numbers will be page navigation keys.
How do you know if the CAPS LOCK button has been activated: do not see any indicator ?
I have the same keyboard and it does not have a caps lock lamp.
The only way of knowing if the caps lock is on is to type something in a text window although some websites will tell you if your caps lock is on as this can cause errors when entering passwords etc.
1helpful
2answers
How can I tell if caps lock is on please? I have an Acer 5732Z
You can use the Keyboard Acessbility options to activate sounds for these keys (CAPS, NUM and SCROLL LOCK) for XP just follow these steps http://www.worldstart.com/tips/tips.php/102
Can not log into my yahoo messenger
try to check your internet connection if connected to
the internet. please check also your username name and your password and the caps lock button is activated..
When my wife logs in her account, the keyboard does not work for her, however it works perfectly for me. I was sure she had changed some settings somewhere, but I could not figure it out. Second question;...
Has the keyboard been deactivated on your wife's account.
Go into control pane and check.
All keyboards have 3 lights above the number pad on the right hand side.
Middle light is for Caps Lock.
On laptops the light might be on the Caps Lock key itself.
Sometimes when you press the key, check the bottom right hand side of your screen and it may tell you that Cap Lock is On/Off
2helpful
2answers
Cap Lock on or off
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
