Walkman won't turn on and the lock symbol is displayed on the screen where the clock is
Had the same issue with this Walkman. You need to know about soldering techniques.This is what I did to fix it.Open the Walkman (4 small screws to the back two of which are located in the battery compartment). Unsolder the pin on the switch to the right and solder the other two pins together.The key symbol on the display turned off and I was able to access all the buttons and controls.Apparently the switch was faulty...don't need it anyway! Hope it works for you. Good luck!
Hey JT Tai, I appreciate your post!
The symbol at the top left hand side of your display could be child lock symbol or vent symbol. If it is the child lock you should be able to press and hold the stop/cancel button down for 3 seconds to release the child lock.
If the light is on for the vent I would seek assistance from a professional for proper diagnosis and repair to be completed on your microwave. I hope this is helpful. -Matt
