I constantly get a tE error code when the machine is sensing the load of wash. I unplug the machine, rearrange the clothes in the machine and try it again. Usually that does the trick and the machine will work fine for weeks or sometimes it will do it all the time. What is causing this to happen?
Te is a error code for a bad thermister. it senses the temp of water in the tub. this needs to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
SOURCE: LG WFT851 - Flakes of dirt problem
try putting some milton or baby bleach into the machine with the hottest possible wash with no clothes with the highest water level
SOURCE: LG WM2688H Front Load Washer
I do not have a solution, but have the same exact problem and would like to know if you ever found out where the thermistor is and if you were able to fix it.
Thank you,
Treegirl
SOURCE: LG WM2077CW (UE error code)
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
.....& rate me if helped.
SOURCE: LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
Finally called a local appliance repairman. They came to the house with a new heating element, but found out that I didn't need one. All that had to be done was to hard wire the wires. The thermister was fine. He told me that the thermister is rarely the problem with an tE error code. The total bill for 1.25 hours of services was $106.00!! My husband, who is extremely handy, told me he never would have had the right tools or know how what the problem was to fix our washer.
