Mini cooper convertible top won't go up
do you hear hydralic motor if not use test light while operating control switch up and down position, you need a helper for this procedure.if power is at switch, see if power at hydralic motor while helper work the control switch, if no power at motor hook test light to good ground if no power at hydralic motor check fuse.if power at hydralic motor and you hear no sound hydralic motor bad.if power going to control switch and not to hydralic motor either control switch bad or you have broke loose wire at switch going to motor.if all electrical system okay and when you work the up switch and hear hydralic motor running your hydralic fluid level low reason why convertible top not going up.check fluid level at the side of the motor and pump you should see screw type check plug.you should have see through side reservoir fluid level should be between min and max marks.if fluid is low check for leaks at the pump hoses and hydralic cylinders.
