SOURCE: Peg Perego John Deere tractor 12volt will only
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
SOURCE: tractor won't go in low gear or reverse
I had the same problem and replaced the shifter which I found at
http://www.mypegperegoparts.com/switches.html.
This fixed all the speeds and now it runs great.
Hope this helps
SOURCE: wiring diagram for john deere peg pergo tractor
its in the owners manual here http://us.pegperego.com/admin/archive/manuals/Turf_english.pdf
SOURCE: how to replace rear tires on peg perego john deere tractor
remove the center cap of the tire, the remove the metal push nut, then pull the wheel off, do not pull out the axle there are spacers by the gearbox that are on the axle
