SOURCE: IBM X226 server
i have two x-series server but in one server with one power cords it is showing green light but in case of another server it is comming yellow light.
SOURCE: Raid configuration
When your system boots up you should see an option to access your raid controller if not or if your system doesn't see the controller at all you will have to download the utility software from IBM, but you need to be careful any change you make in the configuration of the disks will delete all data on your drives. This is non-recoverable loss. The utility has help and is fairly easy to understand.
SOURCE: server on but 2seconts automaticaly off. server
Sounds like an overheat issue or ram issue. Look up the beep codes if there are any
SOURCE: MY IBM X226 switched ON but no display?
Please Check the display Cord And Also Cleanup the ram!!
SOURCE: can I install windows 2008 R2 on ibm x226 server?
You can if your system meets the minimum hardware requirement for Server '08. Check Microsoft website for more detail. You may need to up your memory if it is not above 2GB free and hard drive need at least 1GB for os to install.
Good Luck
C2S
