The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP elevation motor. Use the contact cleaner, you can find it in R .Shack.
see the diagram attached.
God bless you
