Why does my carrier chiller 30GX keep tripping on ground fault code 5.5
SOURCE: model 30gx faults code
Hi, the indoor chiller unit blower section will have a sheet glued to a panel on the unit that will tell you where and what the code 302 means on the unit. Then you will be able to make the repairs you kneed.
Shastalaker7
PS the numbers above show that this is a 3 ton unit, 38CKC036. The error code more than likely will be 3 flashes from the board followed by 02 flashes. I may be wrong on that , so correct me if I am.
The 30GX lists only 2 digit fault codes..here - http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/30g,h-3t.pdf
