I assume yiu had the electronic oven control repaired. Sometimes the touch pad also goes bad. I have had to replace them at the same time. If the oven indicator lights showing the oven being on shows up on the display it could be that the thermal fuse behind the oven has gone out. this in in the common line and will shut down both ovens at the same time but you will get the control panel to respond to the touch pad.
If your Kenmore electric range model 790.9232 oven is not working and the control panel is blank, there are a few potential causes for this issue:
Faulty control board: The control board manages the oven's functions and if it is faulty, the oven may not work and the control panel may be blank.
Power supply issue: There may be a problem with the power supply to the oven such as a blown fuse or tripped circuit breaker.
Wiring issue: A wiring problem such as a broken wire or loose connection may be preventing power from reaching the oven.
Thermal fuse: The thermal fuse is a safety device that cuts off power to the oven if it overheats. If the thermal fuse has tripped, the oven will not work and the control panel will be blank.
It's best to have a professional technician diagnose the issue. They will be able to identify the specific cause of the problem and make the necessary repairs. It's also important to check the owner's manual for troubleshooting options or error codes that might be displayed on the control panel.
It is also important to check if the range is properly plugged in, or if the outlet is working properly. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18-6--/Kenmore-Oven-Won-T-Turn-On
Disconnect power to the range. Remove the rear panel cover. Disconnect....then re-connect all the wires on the oven control. Replace the panels. Plug the range in and try it again. If this does not work the ERC(clock) must be replaced.
You need a new control panel on this unit. We have parts for your Maytag oven. Please give us a call today at your earliest opportunity and I will give you the cost of this part. 972-859-0929 - We can put your part in the mail today so you can repair your oven this week. We hope this answers your question about your oven control panel. We look forward to working with you.
what brand oven, what is the model number, what is the error code seen. Try pressing the cancel button for about 10-15 second. Have you tried disconnecting power to the oven - do so about a minute
