Sport craft dart what is the power suply
The power supply takes in voltage (usually 120V AC) and distributes it among the utilization equipment (motherboard, speakers, monitor). in older standup dart boards it is consists of a system of devices called a linear power supply this usually consists of a transformer, capacitors, fuses, other electrical/current altering devices that are exposed inside the cabinet of the dart board ( meaning you can be seen by simply looking inside.) These "devices" will convert the 120V into a form necessary for that which it is supplying power to. In more modern circumstances where you would see all of this equipment you will instead see a switching power supply. which consists of a metal housing with holes all over it and a on/off toggle switch on the side. Both systems have the same function however a switching power supply contains everything inside the metal housing, meaning you cannot see all of the individual pieces without taking it apart. Under both circumstances the AC power cable will plug directly into said power supply from your wall outlet making it almost impossible to miss.
