I bought this washer from a person but they didn't have the manual for it. How does the wash control button work?
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
SOURCE: Control Locked light on
Hi
Thanks for using FixYa. To unlock the controls you’ll need
to press and hold the DRAIN/SPIN button for 10-15
seconds. Please do rate the solution if the issue is
resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: owner/operations manual, Kenmore Elite
CLICK HERE
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Hello Ruby Torres - I understand that you will like instructions on how to operate the washer, however may I please have the model number so I can assist you better in pinpointing you the information. Generally speaking, the serial tag on a front load washer is usually located on the upper front, as you open the door.
