Lg wf-t9230tp is not pumping
Hear movement or something, but no water coming out.
  • 198 Answers
Open small door at bottom front of washer. get a pail and put small black hose in pail and remove plug. After machine is drained remove large screw cap. probably a sock or something in trap remove and put back in place.
Posted on Apr 23, 2014
Testimonial: "Hi Tom This is a top loader LG Turbo Drum Fuzzy Logic WF-T9230TP washing machine and it don't have any door in bottom front."
  • tom weber Apr 23, 2014
    Sorry about that thought it was front load. sounds like peice of clothing might be stuck in the pump. Not too familiar with top load LG. Try google search with problem
6ya staff
SOURCE:
Simon Ngumbi
SOURCE: LG WF-764STP
Your problem might be the motor capacitor
Posted on Aug 31, 2007
bazuka
  • 3 Answers
SOURCE: My LG TROMM (WM1812CW) does
This code means that something is blocking either the water drain pipe, pump filter or the pump itself. I had the same problem and removing the filter (as recommended by LG) did not help. It turned out I had a piece of debris stuck in the pump propeller itself and consequently the water would not drain and the wash would not finish, prompting the error. This is what I did to fix the problem.
1. I removed the cover on the left bottom corner and the removed the filter and unhooked the little rubber tube (drain).
2. I removed the pump cover (lower left corner of the washing machine) and unscrewed 3 screws holding the pump from the front.
3. I disconnected the power supply and removed the back panel (attached with 4 screws)
4. Disconnected the two hoses (one black, one gray) from the pump.
5. Disconnected the power supply to the pump (I had to cut a plastic tie holding the connector in place in order to bring the connector closer so I can disconnect it).
6. Removed the pump by pressing a little tab that was holding it from the back.
7. Once I removed the pump from the washing machine, I took three screws out of the pump motor, gaining access to the propeller. This is where I found a little piece of plastic. Apparently propeller couldn't spin because of that obstruction.
8. I put the pump back together and attached the hoses. This is easier to do when you have the pump closer to the back opening of the washing machine.
9. I then connected the pump power supply connector, locked the pump back in its place and replaced the screws.
The total repair took less than 45 minutes. The hardest part was to remove and replace the drain tube springs, because I did not have the right pliers (You need decent size pliers or plenty of strength in your hands to squeeze the metal bands).
The tools you need for this repair are:
a philips and flat screwdrivers, large pliers and a sharp knife (to cut a plastic tie)
Posted on Mar 10, 2009
Anonymous
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
rickyrt441
Richard Hale
  • 4399 Answers
SOURCE: My LG washer WF-T124TP fuzzy logic won't pump
I would say your pump is broke. Have you checked to see if it is working yet?
Posted on Feb 23, 2011
caroldon
  • 17130 Answers
SOURCE: Our LG Fuzzy Logic 8.5kg
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Posted on Jul 08, 2011
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
I have a lg top loader washing machine model:wf-t1391tp when wasing and rinsing it makes a huge grinding and crackling sound like is going to brake something underneath motor or gearbox.
Check whether the inner rotating drum is contacting the stationary tub.
The other problems that cause this condition is the clutch assembly and or the motor drive system.
Check both assemblies for security and free movement of rotating parts.
Check also the tub supporting dampers for condition.
Feb 23, 2016 | LG Washing Machines
LG WF-T6517TC my washing machine WF-T6517TC when it start to wash get Alarm "dE" beep and stop machine. what need to do
Don't know exactly what that code is but normally washing machines will beep and switch off quickly if the pump is blocked.as it's not allowing water yo be pumped around.
I suggest that is checked firstly before calling anybody out.
Jan 02, 2015 | Washing Machines
No water/steam coming out of wand
hi there,
do you hear the pump running when you ask for water or steam? You should hear the pump continuously when you ask for hot water, and intermittently when the steam is dispensed.
No hot water or no steam could come from many causes:
valve not working or not actuated (control board), and also the switch that closes when the water knob is turned may be defective.
Do you hear that switch clicking when you open the water knob?
Difficult to help further with so little behaviour information.
Good luck,
M.
Oct 28, 2017 | Saeco Vienna Plus Espresso Machine
Hi there ! I have a LG Top loader WF-T7030TP that wash the clothes but do not want to rinse,spin and drain the water.
you have blockage in your drain in the machine-possibly something stuck in the drain pump like a sock or a paper clip-tear it down-have a couple of old towels handy for the mess-cheers Denny
Oct 21, 2013 | LG WM Washing Machines
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
Install continuous flow hot water system
I dont know if any tankless that have that installed.
Because as soon as it detects water movement it starts heating and if you continuous movement it will heat all the time. If that happens then something is going give and it wont be pretty. With a tank type water heater it just recirculates back to the tank and get reheated as needed.
Jan 10, 2013 | Bradford White everhot outdoor tankless...
Gene, I have a Kenmore Elite model # 665
Hey Steve,Sorry it took me so long to answer i was offline and my add is not supposed to displayed when i am off line so sorry about that.
Now then on that dishwasher with the hum and no water circulation it sounds as if the main wash motor is jammed up for some reason it could be that the motor itself is defective or as simple as something such a piece of debris such as broken glass or almost anything caught in the motor causing it to not turn on,by disassembling the wash motor you can see if something is caught in,if nothing is caught in its a (sorry to say) the motor itself thats bad and would need to replaced.The reason the water drains even though it will not circulate is because of the separate drain pump that is working Please reply back after disassembling the pump to check for debris if ya need further assistance.
Thanks for using Fixya.Com,GENE
Oct 18, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
The dishwasher seems to be cycling - but I no longer get the flush into my disposal and I don't hear much water circulating inside the machine. Also, the soap doesn't all diappear. Any suggestions?
The high pressure water pump is defective and is not spraying the much required jets of water to the dishes.
This is the reason that your dishes are also not cleaned.
You might have to remove and check if the pump is faulty or a cleaning job can rectify the issue.
Sep 11, 2010 | KitchenAid KUDS03FTBL Dishwasher
Washing Machines Logo
202 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
