SOURCE: maxi cosi car seat cabriofix
What seems to be a sewn-up loop, is actually easy to unattach, but the trick is not explained in the manual.
Where the end of the strap seems to be holding to the seat's plastic shell, the plastic is not completely connected, there is a break in the plastic. Just move the strap left/right a bit and you will see that you can unattach it there. Then you can unthread the loose end of the strap and completely remove the cover.
Credits for this go to my wife who figured it out after I already thought we should return the seat to the shop. :p
SOURCE: I need a replacement maxi cosi cabriofix crotch
If you contact www.maxi-cosi.com you will be able to order this part.
I hope this helps.
SOURCE: Is the maxi cosi cabriofix car seat compatible
I just called the Maxi Cosi customer service line to ask this question. No, the carseat base for mico will not work with a cabriofix carseat- different shape.
SOURCE: Where can I source spare shoulder pads for maxi cosi
Check eBay first.
This is from Dorel Juvenile Group (makers of Maxi Cosi) website. "All accessories and additional parts can be ordered from the Consumer
Relations Department. You must have your model number and manufacturing
date of the product to order parts, accessories, or instructions. To
order, e-mail the Consumer Relations Department at [email protected],
fax us at 1-800-207-8182, or write to the following address: Dorel
Juvenile Group Consumer Relations Department P.O. Box 2609 Columbus, IN
47202-2609. You may also contact the Consumer Relations Department at
1-800-544-1108 where you can speak to a Consumer Relations
Representative. Hours of operation are Monday - Thursday 7:00 AM to
6:00 PM EST and 7:00 AM to 4:30 PM EST on Friday."
