Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
SOURCE: Blue will not Converge
This is the typical convergence problem. There are two IC's that need to be replaced. They are soldered into the printed circuit board. If you have no soldering skills, and are in the US, you can take the model number and go to http://www.ptscorp.com, as they will rebuild or sell you a refurbished board . There is a phone number listed at the site if you need help getting the pricing. Good Luck
SOURCE: blue lines on the screen
Remove Convergence / power supply circuit board...replace
convergence IC's with first quality ....either Philips,Toshiba or
best choice = upgrade to Hitachi = CZ 01341....let me know
if you have ? 's............T.
SOURCE: ghost blue cant line up convergence 2lines and blue t on the left of what suppose to be white t
do you desolder from the back of the board
SOURCE: my jvc av-48wp34 tvs green convergences will not line up
REPLACE STK CONVERGE BORD AND RESITOR 1.9
SOURCE: Panasonic convergence- Blue Cross line not able to adjust
The panasonic rear projection convergence repair kit #2 is available for your model at the following link under convergence repair kits which has the ICs and resistors plus detailed instructions.
http://servicemanuals.vstore.ca/
