Question about Amana ARB1917CSR Bottom Freezer Refrigerator
Change water filter in Amana ARB1917CSR
Can't find filter. don't know how to aacess and chaNGE filter
Anonymous
SOURCE:
Anonymous
  • 237 Answers
SOURCE: Water Filter
Look up to the upper right corner of the frige section and you will see a long white tube with a small latch on the end. Looks smaller than a Pringles can in diameter. Pop the latch down and the cover will lower. Hold the back as much you can and twist the filter about 1/4 turn counter clockwise and it should pop out. Once you install the new filter run a couple of "KoolAid" sized pitchers of water through the door to get all the air out of the line.
Posted on Nov 10, 2006
catriver
Ron Marek
  • 878 Answers
SOURCE: Amana ACD2234HRS replacement water filter
Don, I have a manufacturers part number of 67003591, you might be able to cross reference that. Straight from the manual..Catriver.
Posted on Jun 21, 2007
Anonymous
top right hand side of the frigde side. Its the circular looking thing
Posted on Apr 11, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Filter change
didnt post the model number, but a general rule of thumb is the filter is in top right section of refrig compartment, a counter-clockwise turn will unscrew and rescrew the new one in
Posted on Nov 16, 2008
peyton32034
peyton thompson
  • 410 Answers
SOURCE: Where is the water filter in the bottom freezer
according to the model number that you gave this particular unit does not have a filter built into it. most amana bottom freezers ahve the filter located in the refrig section on the ceiling. there is a thumb latch you push in and a cover lets down to expose the filter. then turn 1/4 turn counterlokwise to remove. if this doesnt sound right post back wiht a complete model number from the refrig and I will take another look for you. thanks for using FixYa peyton
Posted on Feb 18, 2009
Intermittent water flow and blinking lights
the water filter should be changed at least every 6 mos. when the filter is dirty it will not allow the water to flow at full force because it is restricted. change the filter and I think that will be the answer.
Apr 16, 2014 | Amana Refrigerators
TOP FRIDGE NOT COOLING
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 27, 2010 | Amana ARB1917CSR Bottom Freezer...
Can the door swing be changed?
Yes the door can be changed to open from the opposite side, there are removal plugs that need to be removed from the opposite side and just change all the hardware from one side to the other, change the middle hinge first and put on the bottom door first, after its is mounted you can put the bottom part of the top door on the hinge and last the top hinge, and just make a few minor adjustments.
Apr 16, 2010 | Amana ARB1917CSR Bottom Freezer...
Defrost not working
Since you've determined the heater is good, check the following items: Defrost timer in fresh food compartment (may not be advancing or the contacts may not be changing from open to close or vice versa), defrost terminator secured to the evaporator (may not sense a rising temperature)
Exploded parts diagram for your fridge:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167592
Generic service manual for Amana bottom mount freezer / fridges:
http://www.servicematters.com/maytag_library/docs/S120_0R0.pdf
http://www.servicematters.com/maytag_library/docs/T120_0R0.pdf
I hope this helps!
Sep 28, 2009 | Amana ARB1917CSR Bottom Freezer...
Amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Mar 15, 2009 | Amana ARB8057CSL Bottom Freezer...
Amana SZD26VW about 10 years old - no water or ice
probaly the water inlet pump behind the fridge is defective or the filters are clogged I'd change the filter first if this dosen't help i'd say change the water inlet pump
May 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Change the water filter
Most are ok to pull as there is a shutoff in combination with feed lines... If in doubt and the water shutoff is convienient to get to turn it off. Otherwise just pull the filter...especially if it simply snaps into place as it should take care of turning off the water as the filter comes out....
Feb 15, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Jun 20, 2007 | Amana ACD2234HRS Side by Side Refrigerator
Amana ARB1917CSR Bottom Freezer Refrigerator Logo
27 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
