Garden Logo
A
Amanda Posted on Apr 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drive Belt on my LT166 John Deere riding mower keeps breaking. WHY?
Changed end of last season broke first mow of the year. Also something is breaking blades on fan.
Daryl Gleaton
Level 3:
  • Master 749 Answers
  • Posted on Apr 18, 2014
Daryl Gleaton
Master
Level 3:
Answers
749
Questions
0
Helped
234313
Points
2170
The bearings may be bad and freezing up, this will cause the belt to smoke and tear up. Does it smell like burning rubber ?? If not then you have a pulley out of line and or a pulley that's cracked or broken. Also check and make sure the deck pins are all in place and the locks are down on the quick release decks. Hope this helps, plese post solved on fixya.com.So I get credit for a solved problem if it does. If not, check back and give me more info.
Testimonial: "I will check for these problems thx I will get bk in touch."
Dennis Key
Level 3:
  • Garden Master 2,481 Answers
Dennis Key
Garden Master
Level 3:
Answers
2481
Questions
Helped
749768
Points
6126
Something in the space. Breaking the blades, a stick or etc.
5 Related Answers
Phil Rivera
  • 83 Answers
  • Posted on Mar 30, 2009
SOURCE: belt broken on riding lawn mower (john Deere LT
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
This link will send you to the illustrated parts list on the john deere site. It shows the belt routing in the part diagram. Hope this solves your headache.
Anonymous
  • Posted on Jun 21, 2009
SOURCE: John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Anonymous
  • Posted on Jul 25, 2009
SOURCE: need to replace belt on deck of john deere riding mower
does the belt on a 42" scotts lawnmower go behind the tenisoner or in front of it?
Anonymous
  • 123 Answers
  • Posted on Sep 01, 2009
SOURCE: need a diagram on how to put a drive belt back on
It is a hard one to put on co look at the picture carefully there are two pulleys one that one side of the deck that are trickey.
Anonymous
  • 5 Answers
  • Posted on Sep 04, 2009
SOURCE: How to install a drive belt on a john deere 175
Photos and description available at
http://outdoorpowerinfo.com/repairs/deere_175_drive_belt.asp
Why does the belt on my mower deck keep breaking?
if i had to guess, i would check and see if the pullys are alinged. Sounds as though you are getting a lot of heat damage or wear to break 3 in one season. I hope this helps you.
1helpful
We have purchased brand new john Deere, troy bilt and some other brand (I can't remember) lawn tractors over the last 5 years and they all go through about 3-5 belts from May to September. Each belt is...
What comes to mind is that the belts are being overly stressed on the new equipment. I can't imagine going through so many belts per season. Are the belts breaking or stretching? What are you mowing, High grass, weeds, and at what engine speed ? How low is the mower deck set? What tractor speed is used. Does the top of the deck become clogged with excessive amounts of clippings? Does the mower bog down and strain? These are all factors that can shorten the life of a belt.
May 17, 2014 • Garden
Mes now keep replacing with john deere parts, cant see any reason why, any ideas?
Maybe the drive belt is to small and pulling on the assembly, and in turn pulling enough to break the bolt. probably is fine when idle, but under load the condition changes, causing tension to be applied and snapping the bold. That would be the first place I would look.
I have also had other bolts come out of other assemblies and everything ran fine. Until one day when it didnt and belts snapped and so did bolts as and my transmission. It wasnt a good day. So check your belt alignments, mower deck bolts, spring placement, rear end bolts, etc. Good Luck!!
John deere riding mower will not go forwards or backwards and was just mowing yard with it. it will start it will cut grass but will not move now help
If it is the belt driven version you should have a deck belt and a drive belt. The drive belt is under the engine. If you have the hydraulic version check for a broken linkage at the pump.
4helpful
I need a belt diagram for a lt166 john deere mower 48''deck
From the JD site, you can get the drive and deck belt diagrams here:
***Don't forget to VOTE for the guys who take an interest in helping!
Top Garden Experts
Jay Finke
Jay Finke
john h
