Question about Indesit W 123 Front Load Washer
Door will not open and error code f06 flashes up
The door will not open and error code flashes up. I have tried turning off the washing machine all night but the door is still closed. Is there anyway of opening the door manually before a technician is called out. It is the Easter hols and unlikely to get it resolved until after the holiday
  • Indesit Master
  • 2,699 Answers
If there's water in the tub the door won't open,get a shop vac,stick it to the drain hos and suck out all the water,you didn't send the model number so i don't know what you have,if you have the front panel with the opening on the bottom to clean out the pump you can drain the water out of the black hose to but going to the drain hose is faster,get the drain hose as close to the ground as you can so gravity will also help.when you get the water out you can try unplugging and plugging it back in,if that doesn't open the door,if you have the front panel where you can just remove the bottom panel,take it off,reach up where the door lock is and on the bottom there's a round plastic release that you grab and pull down and it will open the door but don't do this until you get the water out or you'll open the door and water will flow out.if you have a solid front panel remove the top panel and you have to reach down and pull on the door release,a little harder than the bottom panel but doable.when you get the water out the door might open the computer board knows water is in there because of the pressure switch so when you remove the water it might open after you unplug it and plug it back in.also if it's not draining check the pump to see if it's blocked,when you suck out the water if it smells badly you're using to much he soap,you should only be using two tablespoons of he soap that's it,if you use more the washer will stink,your rubber boot will turn black like mold and the soap eats at the spider gear,if that goes it's new washer time,you'll know the drum will bang loudly in the spin cycle.hope this helps you out.
Posted on Feb 05, 2018
3 Suggested Answers
6ya staff
SOURCE:
Michael Crozier
  • 196 Answers
SOURCE: I have an Indesit model
It means motor triac failure on control board, You will need to replace the main control board.
Posted on Mar 02, 2011
ajb4139
ALLAN JACK BROWN
  • 33 Answers
SOURCE: indesit washing machine model IWD 7145S says F06 on display and all lights are flashing. its at the end of wash and door wont open
Hi Sammi,
Have a look in the troubleshooting guide of the User Manual Should find some information to help you there. Good Luck,
Jack:}
Posted on Nov 17, 2012
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Can anyone tell me what F06 error code means on the whirlpool 6th sense 10kg washer? and what to do about it as the screen is flashing but the door to the machine is locked. Thanks
F06 Drive motor tachometer error This error occurs when the main control unit fails to detect the motor speed from the tachometeric generator fitted to the motor either through an incorrect resistance or the tacho is not correctly fitted into place. The machine will try to detect the reading several times before aborting the program ans shutting down with this error being displayed.
When checking ensure that the drive belt and belt tension are okay as this can cause this error.
  • Check tacho resistance
  • check tacho placement
  • Check wiring for shorts
  • Check wiring harness connections between motor and main controller
  • Check drive belt for damage and tension
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
May 26, 2015 | Whirlpool Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Indesit model iwe7125b problem f06 what does it means?
F06 : DOOR LOCK fails to close/open, door lock triac open/closed, frequency signal fault.
Action: Switch off the device. Disconnect power. Wait about 3 minutes. Open the door, then close, reconnect device to the network. Start device
Dado
Dec 20, 2014 | Indesit Washing Machines
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
I am greeting a flashing code of F06 as in goes into spin cycle and it stops running.
The F06 code will indicate a drive motor tachometer error.This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes.
The error code F06 is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling a service technician to check the connection.
Hope this helps.
Shane
Apr 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Mar 05, 2010 | Washing Machines
F06 and F14 error codes
Before you replace the control panel use a tester on the cable to check continuity .. if the cable is faulty you will get this fault
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Indesit W 123 Front Load Washer Logo
1,025 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
