Question about Amana Refrigerators
Intermittent water flow and blinking lights
Have Amana XRSS267BB and water flow from dispenser is now intermittent and water and filter lights are blinking together and there is a clicking noise whilst they are blinking. Does this just require a new filter? I am new to this F/F.
  • 958 Answers
The water filter should be changed at least every 6 mos. when the filter is dirty it will not allow the water to flow at full force because it is restricted. change the filter and I think that will be the answer.
Posted on Apr 17, 2014
6ya staff
SOURCE:
MARK FISHER
  • 87 Answers
SOURCE: Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
Posted on Sep 06, 2007
Anonymous
SOURCE: No water, no ice, no light
Just had this exact problem and called for service. Broken wires! There's a spot where the wires come into the door that can get pinched from successive door openings. Some service techs will tell you you need a new door because the wiring is foamed into the door, but this tech just respliced and taped up the wires. Open up the black plastic cover on the bottom and look through the mesh wire holder that goes from the corner of the fridge up into the door.
Posted on Apr 04, 2008
David Coomer
  • 1073 Answers
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Posted on Jun 13, 2008
Anonymous
SOURCE: RS21DCNS water dispenser isn't dispensing.
your fridge is slowly icing up, you'll next notice the fan being noisy. read this article and ring samsun on the free phone number
http://www.bbc.co.uk/consumer/tv_and_radio/watchdog/reports/consumer_goods/consumer_20080407.shtml
Posted on Jul 03, 2008
Anonymous
  • 360 Answers
SOURCE: Water dispenser not working
The filter you installed was empty, You will need to purge the air from the system. Simply hold a glass in the dispenser with water selected until water flows.
Please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 16, 2009
MODEL XRSS267BB REPLACED WATER CARTRIDGE RESET CONTROL BOARD BUT STILL WATER AND ICE ARE DISPENSING TOGETHER ANY IDEA WHAT THE CAUSE MIGHT BE ????
thanks for providing a model number I know this answer is a little late but there's no easy way to tell you how to find a short circuit causing the dispenser and the ice auger and ice door to open and activate you have a short circuit in the dispenser control to resolve this problem sorry wish there was an easy answer
Appliance 911 Sea Breeze
Sep 21, 2015 | Refrigerators
Amana AR2664bw dispenser lights
Are you talking about the inside lights are the dispenser lights?
Nov 01, 2008 | Amana Refrigerators
The inside water spout on this refrigerator stopped dispensing water
Checckwater pressure.The 1/4" water supply line should deliver at least 9 ounces of water in 5 seconds. If not, the water pressure is low. Make sure the dispenser is notlocked. Some models have a lock feature that deactivates the dispenser andcontrol buttons. The lock button is located on the dispenser front cover.This feature controls unintentional dispensing. Press the"Unlock" or "Locked" button to reactivate the dispenser andallow dispenser function. You may need to hold the button for2 to 3 seconds. A clogged or incorrectly installedwater filter will reduce the water flow to the water dispenser. Check for aproblem with the filter by removing the filter and operating the dispenser. Ifwater begins to flow, then the filter is either clogged or incorrectlyinstalled. A clogged filter will need to be replaced. Thanks.
Feb 03, 2011 | Amana ARB2259CS Bottom Freezer...
Water and ice work intermittently. Is it freezing up? what position should the wire device be in to work? up,or down? Is that an on/off switch? It has had water,and made ice,but now there is no water...
The ice maker arm should be down for the ice maker to operate. How was the water dispenser flow rate when it did work? You may have a restricted filter, a frozen water reservoir (located behind crispers in fridge) or possibly a bad valve (at the back of the fridge where water connects) . You should also check your shut-off where your water connects, saddle valve type connections are prone to restrictions- try closing and opening it a few times.
Hope this helps!.
Jun 14, 2010 | Amana SXD524VW Side by Side Refrigerator
Slow water flow from water dispenser
Check water supply make sure you have ample water and not a kinked connection from supply. It is a common failure on Amana to have a defective Filter/Head assembly.
Mar 28, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Intermitant water to water dispensor and no ice
water valve, or water pressure problems.
Oct 07, 2009 | Amana Refrigerators
I have a Hitachi R-M800GM.
When i operate the water dispenser, water flows out from the dispenser [not strong flow]. There is also water flowing out at the bottom of the freezer door [hinge area]
I think the line running inside the freezer door may have come loose? If so, how to reattach it? Do u have any layout drawings of how the hose is being connected.
Please help.
Thanks,
Rick
May 31, 2009 | Amana ARS2464B Side by Side Refrigerator
clarkco
Feb 16, 2009 | Amana ARS2464B Side by Side Refrigerator
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
