Doug Thorley 2003 Toyota Tundra - 3.4L V6, without smog fittings - Headers Logo
A
Anonymous Posted on Apr 16, 2014
Won't accelerate, engine bogs down
Check engine light solid,
Kevin Crompwell
Level 2:
New Friend:
  • Expert 56 Answers
  • Posted on Jul 30, 2018
Kevin Crompwell
Expert
Level 2:
New Friend:
Answers
56
Questions
0
Helped
31104
Points
148
Have the catalytic converter checked for a clog and watch tis video on YouTube: How To Fix A Rough Running/Starting Toyota
Car looses power, bogs down check engine flashes rapidly. No acceleration, then 15 - 30 seconds later power comes back and check engine light goes solid and stays on for 2 or 3 days.Anyone with idea?
You should read check engine code.
It tells you more than you can guess.
You can buy quality $1000 snap-on OBD scanner or $30 cheap one.
$30 will do good job. (you need to google after car tells you error code because cheap scanner shows only code but not meanings in plain English)
or you can visit local autozone and ask them read code for free.
unless you ask car itself, nobody will be accurate.
What would cause my 1990 chevy cheyenne to bog down while accelerating ?
The idle air control valve only controls idle speed.
The most common causes are restricted exhaust or air intake, or low fuel pressure.
Is the check engine light on ?
Why does my vehicle bog down when I accelerate from a start?
Try a different machine to read the codes then post a reply ,i have no idea what could cause this on this engine as remember that anything over 1.6/2.0 litre is regarded as a big negine here in europe ,most i work on are under 1.2 ,but if its not accelerating from idle then i would suspect a vacumn leak to one of the sensors but not having much practical experiance then i couldnt say exactly
Reduced engine power code on dash
if you have a check engine light on check the codes first.
95 gmc sierra won't hold steady rpm
Sounds like wiring problems with the engine harness.
The oil pressure not working could cause the hard starting problem.
The idle problem could be a faulty idle air control valve or a vac leak.
I would start with the check engine light and find out what the codes are.
3answers
Would an idle control valve cause a car not to accelerate?
no, idle air control valve is literally to control your idle speed.
what happen when you press on gas? car shakes, RPM goes up, or engine just bogs down?
Check engine light and dead end throttle
can be anything need to be scanned auto store such as auto zone and advanced auto do it for free to get the trouble code
2helpful
Bogs down upon acceleration
You have coil over spark plug ignition and one of your coils is bad.You need to find the bad coil and replace it.
Check engine light comes on & engine bogs down
you need to have it scanned for codes
Top Doug Thorley Equestrian Experts
Imagdrider
Level 1 Expert
john h
ADMIN Andrew
ADMIN Andrew
Are you a Doug Thorley Equestrian Expert? Answer questions, earn points and help others
