Have had my TV for just under 2yrs, I moved from my bedroom to lounge was going great, till flatmate tried to turn on tv using remote, not sure what he did, but I tried to turn on my tv via remote. red lights show when off, when I use remote, tv attempts to turn on where the red standby light goes out, then within seconds the tv will turn off automatically, and red lights show on standby again. have tried manually, by using switch on tv same senario, turns on then off within seconds automatically. Please help me
Shorted circuit board components. Contact any service technician or the authorized service centre for LG, to confirm. Troubleshooting to plasma TVs is really a skilled work. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
SOURCE: power light blinks red, TV doesn't turn on
if you are not technical i sugest you have this checked out by a professional most probably a fuse has gone from iside or your driver board has gone down. The blinking should be normal after you have turneds it off because some capacitors will be discharging.
SOURCE: LG 19 LH 2000 no picture or sound
i have exactly the same problem and my tv is just 2 weeks old !!
any soloutions?
SOURCE: The tv cannot start. No
Hi Julia,
Your unit missing some output voltage(s) in the power supply section. This is commonly caused by open/shorted voltage regulator IC, open fusible resistor, leaky/dried electrolytic filter capacitor in the power supply section. You can't fix this kind of problem if you don't have necessary tools and test instrument, don't know safety precaution. But good news, you may replaced the entire board for your convenient. Click the link below to have an idea how much money you are going to spend on the board.
http://shop.ebay.com/i.html?_nkw=LG+32LG30&_sacat=0&_odkw=Harman+Kardon+AVR+2500&_osacat=0&_trksid=p3286.c0.m270.l1313
http://www.shopjimmy.com/catalogsearch/result/?q=LG+32LG30.
If you still wish to save some money, I would advice you to send your power supply board to repair shop. There's some shop that repair only the power supply board even not sending the entire unit. It will charged you a much cheaper.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
SOURCE: LG 32LH2000 My TV was turned of last night in the
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
