Not sure how tech savvy you are, but the service manual can be downloaded at http://www.parts.singerco.com/CPpartCharts/Presses/MP4.pdf
UNPLUG THE IRON. Figure 7 shows the wiring. Note that the lamp inside the switch is shown incorrectly. It should be on the other side of the switch. Also the 2 wires running down to the fuse are the red wires. The red wires are interchangeable. Use a continuity tester between wire 2 and wire 3 to test the thermostat. Should be open when dial is turned to the left. Closed when dial turned to the right. Also check continuity on the heaters. If everything looks good but it still doesn't work, replace the circuit board.
steven882 . . . You're a good man. I'm savvy enough since I have repaired my Singer Magic Press 4 once previously. My problem is I need a new circuit board; my old one is burned out.
The info on the old board is:
201762 pc1 WORLDTRONICS WT - 3089 (all on top of board).
The number "201762" is also on the bottom of the board.
Can you tell me where I can get a new board?
Thank you for your courteous attention to my problem, and hopefully a good answer!
Scott Mercer
[email protected]
Probably need new auto shut off board
