I was in the process of transferring theh pix to my computer. I removed the memory card to insert it in my computer and then it started flashing intermittently and it wouldn't shut off at all. I kept trying to shut it off and it finally did; however, I seem to have lost most pictures except for just 3 or 4 of them. Is there a possibility to get them back?
SOURCE: Memory card flashes full when it's not
There should be a "format card" option in the camera's system menu. do this and it may help the unfortunate equipment realize the situation:) (be sure there are no pics you want to keep as they will be permenantly removed)
SOURCE: Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
SOURCE: Nikon 4300 CF Card Erro
The Nikon Coolpix 4300 only supports the FAT16 filesystem, so it can only support a 2GB partition. To support 4GB you need a FAT32 filesystem.
Put the card in a CF writer and attached to a PC or Mac. Partition 2x2GB partitions, then format them as FAT16. Now put it into the Coolpix 4300 and it should work.
SOURCE: How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom. Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
SOURCE: Nikon coolpix 4600: How to transfer pictures from camera to card?
ok I figured out how to do it! put the memory card into the camera, then go to view the pictures. Then press the menu button and scroll until you see the copy button. Then you will see the option to copy from camera to card, or card to camera. Press the option to copy from camera to card and press select all....(or whichever pictures you want copied...I wanted all pictures copied). Then voila! it takes a few seconds to copy from the camera to the card, and there you have it! :)
