SuperMicro X6DAL-TG Motherboard Logo
A
Anonymous Posted on Apr 13, 2014
Does super micro motherboard X6DAL-TG work with windows 7?
The driver can't instul by windows 7.
Lars Olsson
Level 3:
Brigadier General:
  • SuperMicro Master 3,400 Answers
  • Posted on Jul 03, 2015
Lars Olsson
SuperMicro Master
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1048546
Points
10330
IT'S ALLWAYS STANDS IN THE MANUAL WICH Os ARE
COMPATIBLE WITH THE MOTHERBOARD.
Christopher Smith
Level 2:
Champion:
  • Expert 261 Answers
  • Posted on Jul 02, 2015
Christopher Smith
Expert
Level 2:
Champion:
Answers
261
Questions
0
Helped
62360
Points
404
There are a lot of drivers that will not install under Win7.
I set up one last month, and I think it was necessary to use Win8.1,
32 bit with the default Microsoft drivers,
but my memory is in very poor shape.
1 Related Answer
Jeffrey McDaniel
  • 669 Answers
  • Posted on Mar 12, 2012
SOURCE: how do i make my supermicro X6DAL-B2 motherboard more compatable with windows 7?
Sounds like you need to go to the manufactures website and download the latest drivers. I would do this for the motherboard and any equipment plugged into it (soundcard, graphics adapter, monitor, printer). Update everything. Then you might also trying cleaning up things. For example: how full is the recycle bin? When was the last time you defragged the harddrive? How much stuff do you have running in the background? Is windows up to date? When was the last virus/malware scan done and is the software upto date? All these things should be looked at.
Hope this helps
Graphcis card wont work
You have received some wrong information.
This motherboard has a PCI-e x16 slot(ver1.0), two PCI-X 66MHz, and two PCI 33MHZ slots..
The video card must go in the PCI-e x16 slot.
The x8 lanes are hardwired from the Tumwater chipset to the BCM5721 LAN chip, and are not accessible for use.
There is no x8 lane slot on this motherboard.
Supermicro sata controller detects but won't initialize dvd
Make sure the DVD is last.
This means it is plugged into the highest number SATA connector.
How do i make my supermicro X6DAL-B2 motherboard more compatable with windows 7?
Hope this helps
1helpful
Need sound drivers for pc model MS-6743 fro windows 7 OS
There is no sound driver for your motherboard. Your motherboard is not Windows 7 ready. It is too old! Before you installed windows 7 did you run the windows 7 checker? It is available on the Windows website.
Searching for network driver
Hi Ronnie,
Have a look here:
SuperMicro Driver Support
You will need to fill in which operating system your using from the drop down menu, then you can chose which driver you need from the last drop down menu.
Cheers
Myke
Have a supermicro x6dal-tb2 motherboard, upgraded to windows 7. Can't find drivers for the Sata Raid controller. Help?
That driver will be issued by the RAID card manufacturer. If this is a software RAID controlled by the motherboard, your only hope is the latest BIOS firmware R1.0c:
Super Micro Computer Inc Products Motherboards Xeon Boards X6DAL TB2
1helpful
G41tm-e43 + windows 7:
just install ur orignal window 7 driver for ur motherboard
http://www.msi.com/index.php?func=proddesc&prod_no=1791
follow this link
Getting the foxconn 661gx7mj ethernet driver with windows 7
You can try the driver at the following link, if it doesn't work, you'll have to wait til foxconn designs a Windows 7 driver.
For now, buy a Windows 7 compatible ethernet card and install it
Top SuperMicro Computers & Internet Experts
Julie Clark
Julie Clark
ADMIN Eric
ADMIN Eric
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
