John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
r
richard steward Posted on Apr 13, 2014
Have to pull 600gator to start it
Gator has to be pulled first time to start it and will start after running it for awhile
straittalk
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Apr 13, 2014
straittalk
Contributor
Level 1:
New Friend:
Answers
38
Questions
0
Helped
11818
Points
93
Push you stick to press it into nutrueal if that does not work wiglle back and forth on your seat while starting your tractor to move the wheels back and forth this may be a safty mechenisim desighned into your model
I have an older 4x2 gator.sometimes when I go to take off it makes a squealing noise like the brake is on and if it goes about 15 feet it will quit. and it feels like the brake is on.
If a brake is binding try driving in a straight line on tarmac, lightly grip the steering wheel and brake firmly. The gator will 'pull' toward the binding brake. So pulling left is a left side brake and pulling to the right is a right side brake.
Another test is to chock a wheel and safely jack up each wheel enough to clear the ground and turn each wheel by hand. A binding wheel will feel tighter or won't turn at all.
I have a gator xuv 4x4 620i and it won"t start but makes a clunking sound instead
check starter bolts pull plug and do a compression test clunk in engine never good possible spun rod bearing
Car starts right away in all weather drove it for 15 min pulled into drive way and it was running for three minutes and stalls motor was pretty hot then have to wait awhile befor.can restart
would try and bring the temp down by lower degree thermostat hi-volume water pump bigger radiator maybe even double check timing sounds like you might be boiling fuel and hydro locking it
2004 John Deere Gator CS
The voltage regulator/rectifier will not affect the starting. Pull a plug wire off, turn the key to try to start to check for spark. If it has no spark, replace the coil pack or make sure it hasn't rusted between the flywheel and the coil contact. You can get more detailed info for small engine spark and coils on you tube.
Dec 15, 2017 • Motorcycles
Gator lacks power when running in our front yard grass.
sounds to me like you have a bad motor, yes both wheels should turn
How do we replace the rear wheels on the John Deere Gator?
remove the center cap then bend the metal push nut with a needle nose pliers and pull it off then pull the wheels off leaving the axle in place
2helpful
Van dies after 10 min drive when pulling into
Try removing the idle speed motor on side of throttle body, and spray it clean, as well as the port it came out of, with throttle body spray cleaner. Don't pull and extend shaft of idle motor, just leave it in position it's in, and make sure you don't lose small "O" ring on idle motor. Re-install and try it. If it cures it for a while, then starts to do it again, replace the idle speed motor.
3helpful
2answers
Imurray 22" psuh mower will not stay running
No problem. If you found this helpful - a FixYa rating is appreciated for answering your FREE question.
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
