In device manager device driver has yellow mark on it i tried all drivers no luck
Check with support.dell.com for the drivers, but there may be another issue with that machine.
The Optiplex 260 has a 97% failure rate due to some bad capacitors which were sold at the time. Pop open the case and look for swollen or leaking capacitors on the motherboard - this may be the actual issue. These can be replaced at an electronics repair shop or by swapping out the motherboard.
Here is an article which will help you identify the problem better
http://hothardware.com/News/Dell-Blames-97-Optiplex-Failure-Rate-on-Everyone-Else/
Testimonial: "thanks for quick reply its gx280 not gx260 sorry for miss writting"
SOURCE: reloading software, Hard drive replacment
i hope u re install your operating system,
after the re installation u did not install the drivers that is the reson, best way u buy an ethernet card and try to get net connection and down load the drivers from dell.com ,then remove the card ,thats it.
SOURCE: USB drivers
ahuh..remove that usb controller, and then do a hardware scan for differences should work well
and by the way, got backup for that Dell?
SOURCE: dell
if you have the dimension 4600 , you can find all the drivers on the website support.dell.com, its very simple , easy and free to download
SOURCE: cant find ethernet driver
Try the program Driver Max. You can download it for free and update needed drivers.
SOURCE: cannot fix code 28 for network controller for dell1525 laptop
If you are getting a code 28 then you will need to download a new driver on another computer for the network card. If you have a wireless adapter that you can connect to the computer and your router has wireless capability then that could work as well but you will need to get a new driver on to that computer some how.
Finding the driver will be easy though. You can go to the computer's manufacturer website, or the website of the network card's manufacturer and search for it there. Shouldn't be too hard to find but if you can't find it let me know and I will get you a link.
Download the driver software by
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
using this link you will be able select your drivers (appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio volume advanced speakers make sure you have selected the
hope this helps
or you might have to download one
http://download.cnet.com/realtek-rtl8139-810x-family/3000-2112_4-82823.html
http://download.cnet.com/realtek-rtl8139-810x-family/3000-2112_4-96337.html
if these driver packages aren
