Proscan 7-Inch Android Internet Tablet, Capacitive Touch Screen, Android 4.1 Jelly Bean, with Included Case and Keyboard Logo
r
robert kudajczyk Posted on Apr 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keyboard problem hi my daughter have this tablet for short time worked no problem but now every time she put on she gets this message on the screen what to do to fix that unfortunately,Android keyboard (ASOP)has stoped thx and I hope you can help
Mike M
Level 3:
  • Proscan Master 3,349 Answers
  • Posted on Apr 13, 2014
 Mike M
Proscan Master
Level 3:
Answers
3349
Questions
0
Helped
686780
Points
16707
Digiland DL718M
Review: Digiland DL718M Android Tablet Gives the ...
the-digital-reader.com/2015/12/06/94715/
Dec 6, 2015 - Take the Digiland DL718M, for example. ... I also found that the screenon the Fire has a yellow tint when viewing an ebook in the ... fire tablet digiland dl718m... I am happy with it, and that says more than you might think.
DigiLand 7-inch DL701Q Tablet Review: Quad-Core 8GB ...
vbsweb.net/digiland-7-inch-dl701q-tablet-review-quad-core-8gb.htm
Dec 21, 2014 - With a 7" 5-point capacitive touch screen, this DigiLand DL701Q tablet makes .... Hi, my daughter was playing on her tablet and then the screen .... let me donothing just more error messages, when it says to report the error ...
Digiland DL700D Hard Reset - YouTube
? 1:55
https://www.youtube.com/watch?v=Yr7PTiaShQk
Oct 4, 2015 - Uploaded by Android Pro
Digiland DL700D Hard Reset .... I get the Digiland logo, then the green android, then nothing but black screen. ... DIGILAND 7" (DL718M) NEW ANDROID 5.1 LOLLIPOP TABLET HD DISPLAY UNBOXING - Duration: 4:12. by
How do I connect my keyboard to my tablet
If it's bluetooth, put it into pairing mode and turn Bluetooth on from your phone. Put your phone into discoverable mode and pick the keyboard. It might take a short time to show up. Pick it, and whatever code it wants you to on the keyboard.
On-Screen keyboard does not show up.
Hi
User manual under link:
http://www.manualslib.com/manual/555275/Acer-A210.html?page=19#manual
Go to page 19 - 20 where you will find settings to screen keyboard. Try and let me know if helps.
Try to hard reset which will take system to manu. settings by following the steps on video:
https://www.youtube.com/watch?v=gk0IZMPqIic
How do u get unfortunately,retech_ten I has stopped off the home screen of a tablet
rstech_teni is in your tablet as a core system app even though it may be no such thing. I believe it was put there by the tablet manufacturer in some contractual agreement with some advertising entity. The Lookout malware scanner may sometimes detect it as malware you should just ignore it and not try to delete it, as it will result in your problem again.
You will not be able restore the tablet from the hardware restore menu (hold power & up vol) because it will not allow you to answer "yes" to the prompt to proceed.
Two ways to fix, (Later, on how to actually select something)
1. (preferred)
Go to >Settings >Apps >All
scroll down to rstech_teni, select it, and then select "Clear data"
If you don't see retech_teni you may find "rs_9104_v30". This may be a clone of rstech_teni, do the same to it.
Your done.
2. (last resort, you will lose installed apps and data)
Go to >Settings >Backup & reset >Factory data reset,
Follow instructions, and your done.
And now the hard part, to deal with the message that will not let you navigate.
The easy way to get to "Settings" is to short tap power button to put tablet to display off/locked.
Then again short tap to turn on screen. You will see the rstecc_teni MSG hit OK in MSG. The MSG should be gone and not come back, do nothing else other than pull down the right upper drop down menu where the settings button is then select settings. At this point the evil MSG will come back.
From here on the frustration will start.
You will need to use two hands. Tap the rstech_teni OK with one finger on one hand and then quickly tap the Apps option with a finger on your other hand. This is kind of time consuming but it works after multiple attempts.
If you have a stylus pen, use it for the second tap to the option you want. It will seriously reduce the time it takes by making the second tap very accurate.
Within a half hour you should be able to get through this.
I know because I had the same problem.
My daughter got locked out her digiland tablet and dont have a manuel on how to reset because her email she used to set up her tablet is not working how can she get into her tablet
Hi Mercedes, you will have to perform a factory reset to take the tablet back to when new!
Power the Tablet down completely. Press and hold the Power and Volume up buttons until a recovery screen appears. You should be presented with a screen that will allow you to perform a Wipe Data Factory Reset. Perform the reset then restart the Tablet.
1helpful
How do you unlock this tablet? My daughter forgot her password.
You may have to call the manufactor, but try the reset button. Can you take the battery out, if so try that to.
do you have a way to conect to a pc or lap top? Try that sometimes you can do that to
Android keyboard (asop) has stopped working
My Kl? tablet (old one) isn't letting me use the keyboard, only a white bar shows up at the bottom. How do I fix this?
1helpful
How do you put on the little ligh that is on top of the screen
on your keyboard, pressing FN + PgUp (both key at the same time) will turn it on for you.
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
