Question about Garden
How to reconnect kohler goveners
I have an 18hp kohler engine with the govener wiring disconnected. How do I reconnect?
    New Friend:
  • 29 Answers
Without the numbers from the engine I can not get you the exact breakdown you need, this might help.
https://images.search.yahoo.com/search/images;_ylt=A0LEVy51DUpT0jUAMvlXNyoA;_ylu=X3oDMTB0Yjkwb3VoBHNlYwNzYwRjb2xvA2JmMQR2dGlkA1ZJUDM3MF8x?_adv_prop=image&fr=yfp-t-301-1-s&va=18+hp+kohler+engine+governor+diagram
If you give me the numbers including the spec number I will get you the breakdown you need.. Best of luck to you, please let me know if i can help..
Posted on Apr 13, 2014
Anonymous
SOURCE:
Anonymous
  • 22 Answers
SOURCE: I have a Craftsman 18hp Kohler engine. What is
there is no clutch drive belt needs replacing cost of drive belt $20.00
Posted on Sep 02, 2009
mickey813
mickey813
  • 472 Answers
SOURCE: Hello,I have a briggs 13.5hp I/C ohv single
sounds like you you have bad gas and a air leak
Posted on Oct 01, 2009
Anonymous
SOURCE: need wiring diagram for kohler 12.5 engine and
A FREE download of the entire Kohler Service Manual for your engine is available as of 1-29-2010 on the net in the form of a pdf. I don't know how long it will remain available but as of today you can still download it allowing you to reference the area of your concern using the address; www.asberry.net/files/TP-2339-D.pdf. This pdf contains the entire Service manual for your engine. However, it is 147 pages long and if you don’t start with at least a half full cartridge it may drain your black ink cartridge. I downloaded this Service Manual for my Kohler 12.5 engine to help me fix a charging problem and it was a bargain because the download was FREE except for the ink and 147 pages of paper.
Posted on Jan 29, 2010
jmeredith
Jude Meredith
  • 417 Answers
SOURCE: Have a 26hp kohler loses
hi,
make sure you have the correct plugs for it. spark plugs that are too short will cause a condition like that. make sure your air filter and fuel filter isnt clogged.
jm
Posted on Apr 30, 2011
rycgl
Roy Cagle
  • 1545 Answers
SOURCE: briggs straton ohv on tiller
The hard to pull, will not spin the engine issue could be because you need a valve adjustment. A valve adjustment is critical because it enables the built-in compression release on the Briggs OHV engine to function correctly and enable an easy start; plus of course, smoother running. Remove the valve cover and adjust those valves at 1/4" down past TDC on the power stroke. You WILL see a difference in the engine once you do the adjustment.. Here is a Briggs spec chart which has those values for their engines. Yours should be listed in the OHV engine section.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
Here is the Briggs recommended tutorial on HOW to adjust those valves. Scroll down this page to "Adjusting Overhead Valves"
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Servicing%20the%20valves/
Posted on May 22, 2011
Wont run at slow speed. either full on or full off
what engine /vehicle are you talking about/ AS the question again with make model engine size, year and all other details
Nov 29, 2015 | Cars & Trucks
How do i fix my ariens lawn mower
Does sound like the the throttle control govener linkage is either in need of adjusting, The throttle control govener linkage is the part that connects the throttle to the internal engine part a mechanizum that will activate the throttle when the engine is put under a load, to keep the engine from stalling and to increase the RPM Rotations per minute of the engine when their is a load on the engine, by advancing the throttle control in the intake manifold . Or the linkage is binding and not activating properly ! Check to see if the throttle plate does move freely and is not stuck.and that the wire type linkage is connected to the throttle plate !
May 01, 2014 | Computers & Internet
My engine will not stay running until it gets warm, then it runs normal. Could this be a govener problem
Check for blown head gasket or leak at block to carb .Check head bolt s for proper torque .If it were a govener problem it over rev or surge .
Feb 16, 2012 | Briggs & Stratton Measuring Tools &...
'96 2.2 cavalier need manual shift out of first (replaced engine
3 speed auto or 4 speed auto? Does the speedometer work?
Apr 14, 2010 | 1996 Chevrolet Cavalier
Coleman powermate plus 1750, changed gasoline, spark plug, oil. cannot get it to start/run
check the carborator see if the butterfly valves or closed, than see if the govener can move back and forth and than go farther and if you move the throttle will the govener butterfly valves move. if that is stuck move it or use some lubricant and there should be 2 linkages, 1 inbetween the throttle and the govener, and 1 inbetween the govener and the carborator.
Oct 24, 2009 | Coleman Electrical Supplies
Can the govener be removed from the engine
For most newer vehicles, it is programmed into the ECU (computer). Look into a performance chip or Apexi controller to unlock your car's true stock potential.
Sep 29, 2009 | 2003 Hyundai Tiburon
John Deere Mower Engine Issue
HAVE YOU CHECKED THE CARB AT ALL? LOOK AT THE LINKAGE & MAKE SURE IT MOVES FREELY! IF CARB CHECKS OUT MAKE SURE GOVENER IS ADJUSTED RIGHT!!
Sep 05, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Garden Logo
151 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
