Question about Makita LXSF01 Drywall Screw Gun 18 Volt cordless
How much torque does the cordless screwgun have
How much torque does this have in in-lbs
    New Friend:
  • 68 Answers
It usually has that on the label-depends on which gun you have also
Posted on Oct 02, 2017
6ya staff
SOURCE:
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
Can't get rigid zrr8660 screwgun to sink screw more than half way.
Some screwguns have a torque adjustment that slips when adjusted too light. The strongest setting usually has a symbol of a drill bit. Have you tried putting the screw into another piece of wood? If you are going into a very dense wood you may have to predrill hole.
Dec 17, 2014 | Home
2013 ultra classic torque spec's on Rotors front Axle's front and rear
Front axle nut torque 70-75ft lbs, rear axle cone nut first torque 15-20ft lbs, second torque 95-105 ft lbs, front disc torque 16-24 ft lbs, rear disc torque 30-45ft lbs.
Nov 24, 2012 | 2005 Harley Davidson FLHTCUI Electra Glide...
Torque the cylinder head bolts for mitsubishi lancer 2002
Try this
I dont know which engine you have.
420a
1. Torque all center bolts to 25 ft-lbs, torque the 4 corner bolts to 25 ft-lbs
2. Torque all center bolts to 50 ft-lbs, torque the 4 corner bolts to 50 ft-lbs
3. Re-Torque all center bolts to 50 ft-lbs, re-torque the 4 corner bolts to 50 ft-lbs
4. Tighten all bolts in the sequence from #1-#10 an additional 1/4 turn.
7-Bolt 4G63
1. Torque all bolt to 58 ft-lbs in order
2. Loosen all bolts completely to 0 ft-lbs
3. Torque all bolts to 15 ft-lbs in order
4. Tighten all bolt 1/4 turn in order
5. Tighten all bolts an additional 1/4 turn in order.
ARP Head Studs
1. Tighten all bolts to 40 ft-lbs
2. Tighten in steps of 10 ft-lbs increments until the specified torque that you are looking for is reached. This can vary with the amount of boost you plan on running.
Jun 30, 2011 | 2002 Mitsubishi Lancer
1998 FORD FESTIVA HEAD BOLT TORQUE SETTINGS & TIGHTENING SEQUENCE (1.5 LITRE ENGINE)
1978 - 1980 FORD FESTIVA 1.6L 65-70 Foot pounds (Final torque)
Torque sequence 9 3 1 5 7 8 6 2 4 10 Step 1: torque to 5 Ft/Lbs Step 2: torque to 20-30 Ft/Lbs Step 3: torque to 50-55 Ft/Lbs Step 4: torque to 65-70 Ft/Lbs Recheck final torque in sequence
1988 - 1993 F0RD FESTIVA 1.3L
Torque sequence front of engine 8 4 1 5 9 7 3 2 6 10 Step 1: torque to 35-40 Ft/Lbs Step 2: torque to 56-60 Ft/Lbs Recheck final torque in sequence
2011 FORD FESTIVA 1.6L NO TORQUE SPECS AVAILABLE THERE IS NO FORD FESTIVA MANUFACTURED IN 1998 ALSO NO FORD FESTIVA MANUFACTURED WITH A 1.5L ENGINE
HOPE THIS HELPS YOU
Aug 06, 2010 | Ford Focus Cars & Trucks
What is the right Torque Specification of the cylinder head bolt,main bearing and connecting rod bearing for a 1997 Ford F 150 4.2 liter? Thank you...
Cylinder heat bolt torque:
Torque sequence --------- front | 7 3 1 5 | | 8 4 2 6 | --------- Step 1: Torque all bolts in sequence to 14 Ft/Lbs Step 2: Torque all bolts in sequence to 29 Ft/Lbs Step 3: Torque all bolts in sequence to 36 Ft/Lbs Step 4: in the sequence, loosen the cylinder head bolts three turns. Step 5: Tighten short bolt to 15 - 32 Ft/Lbs Step 6: Tighten long bolt to 30 - 36 Ft/Lbs Step 7: Tighten all bolt to 175- 185 degree note: Do not loosen all of the cylinder head bolts at one time. Each cylinder head bolt must be loosened and the final tightening prior on the next bolt in the sequence.
Main bearing torque:
Torque sequence: Step 1: torque bolts to 91 Ft/Lbs with the exception of the rear main bearing cap Step 2: torque rear main bearing cap bolts to 88 Ft/Lbs Step 3: torque brace bolts to 40 Ft/Lbs
Connecting rod torque:
Torque sequence Step 1: Torque to 29 Ft/Lbs Step 2: Turn an additional 90 degrees
May 17, 2010 | 1997 Ford F150 Regular Cab
Is anyone there? need Dewalt help
Here is DeWalt's marketing thing on the subject.
http://www.dewalt.com/us/cordless/powerrating/
Unit Watts out (UWO) is their rating for the (presumably sustainable)maximum power output at the chuck of the drill. You can read about it..their explanation is basically technically correct.
Yes, max torque is related. The maximum power in a permanent magnet DCmotor system occurs at half the maximum speed when the system is loadedwith half the maximum torque.
1hp = 746 watts, DeWalt's DC900 36V drill is claimed to be 750 watts,close enough so let's call it 1 HP ok? Their max RPM is 400. So 200 RPMis the half-way point.
1HP = 200RPM*Tmax(in-lbs)/(24*5252)
Tmax = approx 630 in-lbs
The equation I used is known equation for relating power (HP) to RPMand torque (in ft-lbs..I added in the factor of 1/12 to account for thein-lbs to ft-lbs conversion).
By the way DeWalt make some bold claims about other manufacterers' drills.
For example they claim the 18V Lok Tor by Milwaukee puts out 390 UWOcompared to their DC988 model listed as 420 UWO. Yet I have readinformation from Milwaukee's own independent tests that claim the LokTor drills faster 2 9/16" self-feeds AND more self-feeds per batterythan that very DeWalt model.
This was posted on Milwaukee's Tool Talk forum (when it existed). Ibelieve the Milwaukee official said that DeWalt averaged 7.2 secondsper hole while the Milwaukee averaged 6.4 seconds per hole. I make beoff slightly but I do remember it was around a 1 second difference.Plus the Milwaukee apparently drilled 28 holes per batt where dewaltwas 25.
Feb 22, 2010 | Dewalt DC925 Cordless Drill
Need to the torque specs for a 1999 Dodge Durango
Head Torque sequence Step 1: torque to 50 Ft/Lbs Step 2: torque to 105 Ft/Lbs recheck final torque in sequence.
Torque intake manifold: Step 1: 12 inch/Lbs, (hand tight) Step 2: 72 inch/Lbs, (6) Ft/Lbs Step 3: 12 Ft/Lbs
torque intake plenum: Step 1: 24 inch/lb (hand tight) Step 2: 48 inch/lb (4) Ft/Lbs Step 3: 84 inch/lb (7) Ft/Lbs (To torque bolts, start in center using crisscross pattern)
Apr 07, 2009 | 1999 Dodge Durango
Torque setting
Ok, lets see- I still have my old official shop manual for that bike...Cylinder head nut torque is 16-20 ft lbs,Cam sprocket bolt torque is 12-17 ft lbs, Valve adjuster cover torque is 7-10 ft lbs, Cyl head cover torque is (6mm)- 7-10 ft lbs (7mm) 9-12ft lbs, Rocker arm adjuster nut torque is 11-13 ft lbs.
Nov 20, 2008 | 1984 Honda FT 500
Makita LXSF01 Drywall Screw Gun 18 Volt cordless Logo
629 people viewed this question
Top Makita Drywall Experts
ray gallant
John Donghia Jr.
John Donghia Jr.
Are you a Makita Drywall Expert? Answer questions, earn points and help others
