This depends on what kind of engine you have on the mower. If it is a Tecumseh, there is a metal ring around the base of the bulb that you can remove with a needle-nose plyer. Remove and replace the bulb and ring. The ring important, install it by using a ratchett socket one size larger than the bulb. Place the ring in position and using even pressure on the socket the ring will snap into place.
If it is a Briggs engine there is a plastic ring at the base of the bulb. The application is the same but you should be able to snap the ring on with your fingers.This depends on what kind of engine you have on the mower. If it is a Tecumseh, there is a metal ring around the base of the bulb that you can remove with a needle-nose plyer. Remove and replace the bulb and ring. The ring important, install it by using a ratchett socket one size larger than the bulb. Place the ring in position and using even pressure on the socket the ring will snap into place.
Is it the engine that the carb sits on top of a rectangular gas tank? Is it the engine that the carb sits on top of a rectangular gas tank?
AnonymousMar 15, 2014
Primer bulb on Toro self propelled lawn mower has a hole in it. How to get it off and put new one on.Primer bulb on Toro self propelled lawn mower has a hole in it. How to get it off and put new one on.
You can't post conmments that contain an email address.
Mike what i suggest you do is put a small amount of fuel into the block where the spark plug goes. If it doesn't fire after two pull change the plug. Also find the air filter and clean it.
There is a tab on either side of the carburetor right where the primer bulb sits. You can depress both of these tabs with a screwdriver and pry out the plastic ring that holds the primer bulb in place. You can purchase a new primer bulb (with a new plastic tab) from a local mower shop or from a small engine repair shop. When you install the new primer bulb, put the rubber bulb in first then put the plastic ring on top and press it in until the tabs click on each side. It should work correctly after the tabs are clicked properly. You can take off the air filter and look into the carburetor to see if the unit is priming correctly. I hope this helps you out.
Guessing you have a briggs and stratton motor with a tank mounted carb.Remove the tank and carb. from the mower and replace the rubber diaphram between the carb. and tank and clean it while its off
