Kenmore HE2 Plus Front Load Washer Logo
A
Anonymous Posted on Jan 28, 2018
Getting access to the drum on a Kenmore HE2 Plus
SOmething is stuck inside the drum so when it spins, it gets stuck and makes a grinding noise or a squeak. When the washer is off, I can move the drum by hand and hear something inside that is loose. I need to get in between the plastic outer drum (that doesn't move) and the metal interior drum.
1 Related Answer
Anonymous
  • 97 Answers
  • Posted on Nov 25, 2009
SOURCE: Something loose between the drums
how did the underwire get there, you may want to remove lower panel please unplug washer before removing panel use a flash light there is a area were coins and other objects fall in to also have a bucket there well be water in the lower unit use something to fish it out lucky it did not get caught in pump
I have a Kenmore 110 44932 200 washing machine. When the drum spins it sounds like there is something caught between the walls. At a high speed it make a loud noise. How do you get between the walls
SOUNDS LIKE UN HAVE SOME ITEM OR COIN ETC STUCK BETWEEN THE TUB AND WALL. YOU HAVE TO REMOVE THE TOP PANELS THEN REMOVE RETAINER CLIPS AND REMOVE THE BODY TO ACCESS INSIDE DRUM
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
I hear a scraping sound when the cylinder spins is it a part loose?
Difficult to say as people use different terminology to describe noises; one person's scraping noise tends to be another person's rumbling noise.
It is possible something is loose inside but there isn't much that commonly works loose in a washer. Could be the drum bearings are failing or the tub suspension has broken or become detached but in the case of the latter it would usually be noticed the drum alignment would be changed and a louder knocking as the washload begins to spin.
Something is grinding up against the drum so we can't do a spin cycle...probably a coin or something. How can I get to the outside of the drum to check?
You have to separate the front and rear of the tub to get at basket, which is a major job. You might take a flash light and look through the holes in the basket to see what's rubbing.
1helpful
Over loaded my front load lg washer and now it is not able to spin. Makes awful grinding noise. Is this something I can fix myself?
this hapened to me years ago it was an easy fix I took apart my washer ther should be a belt that almost looks like a belt off a car it probably went off track once you get it apart try spinning the belt you should be able to fix yourself
Very loud banging noise when front load washing machine spinnning
Ensure that the appliance is balanced/level on the floor. Contact an appliance service company.
Buzzing/Ratcheting sound while drying
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
1helpful
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
1helpful
2answers
Weird rubbing or mild grinding noise when in spin cycle.
It sounds like the bearings on your tub are going. This is an expensive and difficult job to do. (approx $450 parts and labour and you may do more damage trying to take it apart)
Alexander
vince
