Toshiba Satellite A135-S4527 Notebook Logo
A
Anonymous Posted on Apr 09, 2014
My toshiba satellite laptop starts up then shuts back off
5 Related Answers
Gino Felina
  • 81 Answers
  • Posted on Sep 05, 2008
SOURCE: Toshiba Satellite 2410-PS241L laptop does not start.
Plug it into the electrical outlet and then turn on your laptop. if it comes on and works fine, then your battery is just simply dead, and if it will charge, just needs to charge. If not, then you are going to have to replace your battery. But assuming all of this is true, and your laptop will power on when using your electrical outlet, then yes, feel free to use it whenver you like when plugged in.
Anonymous
  • 72 Answers
  • Posted on Dec 17, 2008
SOURCE: TOSHIBA LAPTOP SATELLITE A135-S4527 WON'T POWER UP
Not charging . . . And probably the power pin ... where the AC cord connects to thecomputer. That particular component is very fragile. The part torepair it runs between $ 5-$15 but the labor to repair it will costanywhere from $ 100-$250. It can be repaired by you if you are verycareful taking the system apart. Just pay attention to every detail ofyour dis-assembly. I also recommend you get one of these to stop the problem from happening a 2nd time.
Anonymous
  • 371 Answers
  • Posted on Apr 18, 2009
SOURCE: toshiba laptop satellite a75 s209 when i turn on, won't start
Hope these helped you.
Anonymous
  • 42 Answers
  • Posted on Apr 29, 2009
SOURCE: I have a toshiba Satellite laptop that all of the sudden has started shutting down on me when I am in the middle of something. What could it be?
Depends. When you say it shuts down, do you mean it flashes blue and then shuts off / restarts, or just plain shuts off, and stays off?
If it is flashing blue real fast, then shutting off, here's what you do:
While starting the computer, press F8 as soon as the brand logo goes away, and keep pressing until you get a screen that says Safe Mode on it. Then highlight the Disable Automatic Shutdown option, and hit enter. Use the computer until you get the blue screen. It will give you an error message, followed by a stop code. (0x0000ce or something like that). Get that error code, and bring it back here. I'll tell you what it means.
If it is simply turning off without warning, and stays off, most likely it is overheating. In which case, head to Wal-Mart, go to the computer section where the keyboards are, and pick up a can of compressed air. Blow out the computer right where you see the vent on the side (maybe on back), and try that. If that doesn't work, get a laptop cooling pad and use that. If it still doesn't work, then the heatsink for the CPU needs to be recompounded, in which case take it to a shop. Unless that is you ABSOLUTELY know what you are doing and can do it yourself. IF YOU HAVE NOT TAKEN A LAPTOP APART BEFORE DO NOT ATTEMPT IT WITHOUT A PROFESSIONAL, YOU WILL BREAK IT.
Let me know how it goes, and i'll try to help you further if need be.
Anonymous
  • 2600 Answers
  • Posted on Sep 15, 2009
SOURCE: Toshiba satellite A70-KL1 notebook shuts down
Boot off your windows installation disc and choose repair, windows will attempt to repair the startup if problems are discovered. When the repair is finished reboot normally.
2answers
Toshiba Satellite A135-S2356 Need to reset back to factory default
There should be a toshiba option or you can reinstall windows if you like.
Just search for the toshiba settins in
Start
all programs
Toshiba
Toshiba satellite shuts down by its self. and can be turn on back on right away.
go to control panel and locate event viewer. from event viewer select on system events and check on events that causes the laptop to shut down.
hope this helps . . .
1helpful
Toshiba Satellite L505 series laptop would not open windows
Please restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Thanks
1helpful
My Toshiba Satellite A75-S211 computer, will suddenly shut down.
Mine did this and I thought it was overheating and vacumed the back vents. This fixed the problem.
1helpful
Toshiba satellite L305D
That's just the way Windows works when power is cut off. You should set your Control Panel/Power settings to put the PC into hibernation if it's left alone for too long.
Toshiba Satellite M-200 laptop refuses to start
I am sorry. This problem is best solved by doing a complete system restore of you laptop.
Do you have the restore disk that came with it?
2answers
Toshiba Satellite A135 laptop
Try disconnecting power adapter and removing battery for two minutes. If the laptop still does not boot then there is an hardware problem. You can try taking out and putting back ram modules, but my suggestion is to take the laptop at a repair shop, if you cannot fix it by removing battery.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
