When I Turn on its okay but after 5-10 minutes the colors arent normal. Solarized and really messed up. I turn it off wait some minutes then turn on again its normal then after 5 minutes the problem come back
Sounds like the something seriously wrong with the TV. Make sure all the signal cables are tight and also see if the issue happens on all inputs including antenna. If it does not, the issue is just the one input or cable. If it does the TV may need internal service, and you will most likely just be better off replacing it.
SOURCE: black and white picture, then color, need to warm up?
If it is still under warranty, go out and take it to the repair shop now! this could turn out to be an expensive repair if ou have to pay for it. Your problem is the digital board with the tuner on it or the processor board for the signals, like the video and such. This could need the entire boards as most maunfacturers do not supply too many repair parts for these sets. Good Luck
SOURCE: SKY REMOTE NOT WORKING WITH MY NEW LG 42LH3000
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
SOURCE: Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Can Anyone know some tricks?
